Old 06-05-2025, 07:48 PM   #1
Squeak at low rpm?
I have been trying to pin down a squaking sound for a while. I have a 2.7 2003 base model, and at low rpm and under torque load (pressing on the throttle in a higher than ideal gear, for instance, 5th gear at 35mph), a squeaking can be heard from the right side of the engine, presumably through the radiator hole on the passenger side. The squeak increases in with rpm up to around 3000 rpm, when it is not audible anymore. My suspicions led me to a water pump pulley being loose, and grinding into the pump housing, but this didn't fix the problem, as it came back. This time, no loose water pumps are to blame. Does anyone have any ideas or experience of what to check? Any theories would be appreciated!
mrian is offline   Reply With Quote
Old 06-05-2025, 08:36 PM   #2
Have you ckecked the belt pulleys bearings? If not, take the belt out and turn each pulley by hand to feel if those turn without rumble or orthe noises.
2001 996 C2 Manual
pilot4fn is online now   Reply With Quote
Old 06-19-2025, 06:34 PM   #3
Have you checked the idler or tensioner pulleys? A worn bearing in one of those could cause the exact squeak you're describing, especially under load.
we're your trusted source for dc gear motor.
samlevy0515 is offline   Reply With Quote
