Old 03-18-2025, 09:09 AM   #1
Intermittent Starting Issue, 01 Boxster S
Intermittent Starting Issue. Looking for some troubleshooting help on my 2001 Boxster S (986.1, 105k miles, manual).
Lately, I’ve been experiencing occasional lazy starts, and today it has started to not crank at all sometimes when I turn the key. It’s intermittent, but it’s becoming more frequent.
I’m thinking about starting with relays—do they tend to fail intermittently before completely going bad?
Also wondering about the positive battery cable—is internal corrosion a common issue on these cars?
What else should I check? Any insight would be greatly appreciated!
Located in southern Virginia
professorman is offline   Reply With Quote
Old 03-18-2025, 11:03 AM   #2
Run a voltage drop test across both primary battery cables, maximum drop should be less the 0.5 volt.
Old 03-18-2025, 01:15 PM   #3
Thank you. Should I run it from the front to the engine/starter?
Old 03-18-2025, 02:28 PM   #4
Yes..............
Old 03-24-2025, 11:07 AM   #5
Update: I am pretty sure it was my clutch switch that was bad. It has not acted up since.
I made a small jumper for my toolkit with the car, so that if this issue occurs again, I can jump the clutch switch to confirm if that's the issue or something else.
01 Boxster S 6Spd, Speed Yellow w/84k miles. | 991.1 911 C2 7spd Manual | 01 996 C2 -6spd - Green Machine - My baby | 997.2 C2S 6spd | 2x 01 Boxster base
