03-14-2025, 02:42 AM
Bought Boxster S! IMS identification via housing.
Hi!  Long time lurker here with first post. I've been lurking on and off this forum for probably 8-9 years, while dreaming of having a Boxster and learning about the cars. This November I had enough funds to justify it, and my wife pushed me to making the call on a Boxster S 2000 model that needed a little love and maintenance. I have had it in my garage during winter here in Norway, doing the thermostat, water pump, front motor mount, trans oil, motor oil, throttle body/MAF and detailing. A lot of work has been put into the car during these months, and now in april the car goes to a Porsche specialist for clutch, new IMS (EPS roller bearing), and variocam glide pads (found brown plastic in filter  but no metal).
The car is a black Boxster with "Boxster Red" and carbon fiber interiour. It is a US car that was imported to Norway in 2016, having spent most of its 73000 miles life on the roads of Alabama.
Going through the extensive maintenance history of the car, I see that it had problems leaking oil through the RMS/IMS area in 2004 and the RMS and IMS seal was replaced. This was done by Braman Motorcars in west palm beach Florida.
While reading around the forum i found a post where identification of the IMS bearing was done via the part number of the housing, to determine if it was a dual or single row bearing. I have the part number for the housing on my car via the maintenance papers, and have tried googling, parts lists etc but cannot figure it out.
I hoped maybe with the help from the extensive knowledge on this forum, someone could help me identify if I have the single or dual row IMS in my car.
Part number is: 996-105-017-01 SHAFT HOUSING
03-14-2025, 06:32 AM
You will not be able to determine the IMS type from that number, the ONLY way to know for sure is to pull the flywheel and look at the flange; the single and dual row rear flanges are very different, and 2000-2001 cars could have gone either way:
03-14-2025, 08:45 AM
Thank you for your reply. The receipt/papers say "shaft housing" but that part number is for the flange as far as i understand? In the other thread I mentioned the identification of the ims bearing was done with the same part number ending in 02 (while mine ends in 01). I guess the flanges for dual vs single row have different part numbers?
Either way, ims will be changed. I am just curious.
Edit: this is the thread i was talking about :
Buying used Boxster S - IMS flange replaced but not IMS bearing?
03-14-2025, 10:19 AM
Originally Posted by Petecomplete
"new IMS (EPS roller bearing)"
Hello Pete, congratulations on your Boxter!
Out of curiosity, why did you decided to install the EPS roller bearing, instead of the regular ball bearing?
Obviously you have the right to install anything you want on your car, but personally, I have Not read any positive reviews about the EPS roller bearings
03-14-2025, 01:45 PM
Thank you.  Looking foreward to summer now.
No? Have you googled specificly then? Because trawling both this and the BoXa.net forum yealds plenty of positive feedback from people who have it, and with extensive searching and googling, I could not find a single well documented failure, unlike the FVD Brombacher bearing (rebranded SKF bearing) which both Porsche Classic Center (porsche's own center focused on the classics, there are 4 of these centers worldwide) and AutoTech-Sport wanted to use (the only two willing to do the job). FVD is a regular sealed ball bearing like the one originally in the car, but apparently even more failure prone with documented posts of failures after as few as 20 000 km. Porsche classic center recommended against doing anything at all, as they had not seen a orginal IMS failure in 13 years, but three failures of a changed ims (fvd brombacher is my guess). They actually called the whole IMS issue "an american problem", and said they rarely change them. True enough, very, very few 986/996 on the marked have had ims changed in the time I have looked at adverts. I decided to change it anyway, but I'm not putting in the same flawed thing as I am replacing, no way.
The EPS could easily be ordered from design911 in the UK with VAT agreement with Norway, and almost no delivery fee. Also, it comes with a flange so I did not have to figure out if i had a dual or singel row which would cost me as the car would then need to have gearbox out, and then be stuck at the workshop as i waited for the bearing to arrive. So it seemed like the obvious and most hassle free choice, as i would not want another bearing identical to the original.
03-14-2025, 10:06 PM
I was very interested in the EPS roller bearing system for a while, until forum Porsche guru JFP in PA pointed out that the oiling system they devised for the bearing, i.e., poking a hole in the oil pump and directing the oil flow to the bearing through the hollow center of the intermediate shaft, was a flawed design. As folks here can bear witness, I went through many stages of understanding before I finally chose an IMS bearing. Although I argued and fought against it because of the cost, ultimately I realized that LN Engineering's IMS Solution was far and away the best design and the only permanent solution. It has neither ball nor roller bearings, both of which will eventually fail, and it supplies fresh, filtered oil to the bushing-like bearing. Its inventor, Jake Raby, has a number of videos about the Solution. I recommend that you watch a few. Due to JFP's and Jake's irrefutable logic, this hardheaded holdout became a convert.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
03-15-2025, 02:25 AM
I agree. But the oiling system they made for it is totally uneccassary, they also say so themselves. I am installing only the bearing, lubed by oil in crankshaft like any open bearing. The ims solution looks very good, and the LN ceramic bearings also. If you are in the US especially. I know them well, as I have read all IMS related posts on both this forum and boxa.net. truth be told, during last 5 years i have read all posts on this subforum back to its beginning  I considered LN but, over here in Europe i could not find a single vendor that sold LN bearing in a webshop, and the company listed as importer did not have a webshop, nor did they answer email. Further, no LN certified installers in my country. So LN seems to be a US thing. Further, Bad exchange rate from strong USD to weak NOK at the time + 25% VAT made the LN products very, very expensive. The EPS bearing on the other hand was available via UK webshop and ready to ship instantly. I have the bearing already, and give it to the workshop upon car delivery.
But back to the posts Main issue, cannot the type of original bearing be identified?
03-15-2025, 06:16 AM
As noted previously, 2000 and 2001 engines were a transitional period where either bearing could be in play. The ONLY known and proven way to determine which bearing is in the engine is to take it apart and look, period.
My shop has been doing retrofits since they first began, and that is what we do when cars of that vintage come in. All the internet nonsense about VIN numbers, engine seral numbers, build dates, phases of the moon, etc. have proven to be invalid. We have seen very early 2000 cars with single row bearings, and very late 2001 cars with dual rows, as well as the reverse. Visual inspection is required.
03-15-2025, 06:54 AM
Ok thanks again JFP. Appreciate your response. Either way, my insurance provide drivetrain insurance so i do not worry much. Not long before it goes to the workshop either way. I have not bothered bying a foxwell reader to read out cam deviation either, as the brown particles in the filter indicate that I should do that job at the same time either way. Workshop will change pads and chains.
03-15-2025, 09:53 AM
Pete, I could have written that almost verbatim five or six months ago, before my thinking evolved. In an effort to avoid forking over what I considered (and still consider) the Solution's exorbitant cost, I reproduced LN's contradictory statements as a fait accompli. (Example: The sump provides all the oil a bearing needs.) Oiling method aside, the Solution's bearing design won me over, although I came close to choosing their ceramic-hybrid bearing. A shame LN's products are unavailable in Europe. Best of luck on your IMS bearing's longevity.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
03-15-2025, 10:54 AM
Pete, I could have written that almost verbatim five or six months ago, before my thinking evolved. In an effort to avoid forking over what I considered (and still consider) the Solution's exorbitant cost, I reproduced LN's contradictory statements as a fait accompli. (Example: The sump provides all the oil a bearing needs.) Oiling method aside, the Solution's bearing design won me over, although I came close to choosing their ceramic-hybrid bearing. A shame LN's products are unavailable in Europe. Best of luck for your IMS bearing's longevity.
Yep. If there was a importer and a workshop familiar and certifies with the LN product line, i probably would went for the solution myself. There is no doubt it is the best design overall, removing moving parts.
However the IMS issue is considered greatly exaggerated here in europe. Porsche entusiasts know about it, but 95% cars on the marked has not had it changed. Allthou personally i think the 8-10% failure rate proven i the lawsuit is too high for comfort and is the reason i wanted to change that 25 year old, 73000 mile bearing thats in the car now.
I think the eps bearing will be fine. Chances of failure are not 0% but its def a upgrade. Considering its a 25 year old car and all other failure prone components of the m96 engine, i'm ok with the odds. I got the car somewhat cheap, because it was fall, and seller had given up selling it that year. Paint was miserable as well. The part of the reason i did not go for a 996 is the fact that i now have funds for a replacement engine or huge costs should the issue arise. That, and the fact that my insurance company gives drivetrain insurance up to 200 000km (no age limit) with only 1000USD paid by me if engine grenades, leaves me pretty relaxed about this.
I even managed to track down Norways answer to mr.Raby! A guy dedicated to rebuilding these engines. He said he works exclusivly on the engines, no other work on the cars. Rebuilds and work on around 10 engines a year and has been doing that for 17 years. He said if I ever had problems, too contact him. He converts to 3.4/3.6 as well. All the workshops and insurance companies knows him, even thou he stays off forums and doesn't even have a web page. He said he wants the work he does to speak for itself. Very interesting talk with him on the phone.
Now the snow melts, the birds have arrived for spring, and I can't wait to have the car ready for summer!
03-16-2025, 05:14 AM
Hello, Pete. Congrats on your Boxster. As stated here before, there is no way to be 100% certain which bearing you have unless you pull the transmission and look at the flange. Also, check your engine's VIN number. If it has "AT" in it, you have a replacement engine which COULD have the larger, non-serviceable bearing. That's what happened to me. I know you've checked the car's service history, but not everything done to the car is always on there.
Regarding your choice of bearings, got with whatever you're comfortable with. I also considered EPS, but eventually planned to do what Burner did and go with an original style replacement. Regarding the "solution", you can still find a good replacement engine for the cost of an LN's "solution" so, from an insurance standpoint, it's premium-to-coverage ratio doesn't add up. Not even close. Besides, a multitude of other things can grenade these engines, so replacing the bearing doesn't guarantee the engine will last you forever. But that's me. There are people here who love LN and the "solution", and it's a choice that works for them. I'm sure it's a very fine product, but LN soured on me a bit when they wouldn't let me return the UNUSED IMS bearing extraction tool that I couldn't use because mine had the non-serviceable bearing. Like you, I wanted to get everything done while the transmission was out so I bought everything in advance. BTW, I can rent you the tool, if you're interested.
2010 Subaru Forester
03-16-2025, 01:44 PM
Hi, and thanks for your post. I agree with your view on the ims matter. Lots of other things can go wrong on these engines, but its up to each owner how much tjey worry about ims and how much they want to pay to sort it. The IMS solution however does seem to be a good design, allthou pricey. Didn't even think to check the engine number before. I know not all history is complete, because changing the water pump, the coolant was orange/pinkish and not the original green. When i got to the pump i pulled out a Pierburg pump with production date 2006, so it had been changed previously with no record of it. Put a new pierburg in (and low temp thermo), flushed, and added pink G12+ coolant.
Anyways, I checked the engine number now, as I had to jack up the rear to drain out a bit of oil because of slight overfill. Engine number was M96/2167Y02102, indicating it is the original engine. Also now the oil level is 1 bar down from max on the digital display, 2mm down on the dipstick.
Next project is cleaning out the rads, but not sure if i find the time before it goes to the workshop.
