Old 01-01-2025, 06:09 AM   #1
Jack storage locaiton
hello.
We recently purchased a 2000 Boxster and there is a small scissor type jack in the front storage compartment along with a toolkit. Do these cars have a permanent mounting location in that front storage compartment for the jack and tool kit?
Thank you.
santo
1498asr is offline   Reply With Quote
Old 01-01-2025, 06:48 AM   #2
KevinH1990's Avatar
There is a foam insert that fits behind the spare tire. It has niches for the jack and handle. The tool roll fits above the foam insert.
Old 01-01-2025, 10:46 AM   #3
Great! Thank you
Old 01-03-2025, 07:16 AM   #4
Thanks for reminding me to check the air pressure in the spare” I’ve had the car years and never gave it a thought!
-H. L. Mencken
Old 01-03-2025, 01:47 PM   #5
KevinH1990's Avatar
That is thought provoking.
I am wondering whether I should replace the spare tire since it is now a quarter-century old. I have a 20-year-old Mercedes C230. When the valve stem on the Mercedes' compact spare failed, I asked Discount Tire to replace the valve stem. The service writer told me that they couldn't work on a tire of that age due to liability issues. I eventually found a garage that would replace it, but I am aware that tires deteriorate with age. It might be best to consider my experience with Discount Tire "a word to the wise."
Old 01-03-2025, 03:45 PM   #6
Multi-Boxer Driver
Deserion's Avatar
Had that same issue last January with my Boxster. Ended up ordering a new tire from Tire Rack:
Continental SContact SL T125/80R-17
The fit is a little more snug but it still takes the cover and clears the frunk trim panels.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 01-03-2025, 05:57 PM   #7
elgyqc's Avatar
I am wondering whether I should replace the spare tire since it is now a quarter-century old...
I do check the spare tire pressure yearly... good thing. Two years ago I had the right front tire blow out on the freeway (in passing, the Boxster was very stable running on 3 tires). The spare went on and we continued on home without incident, using secondary roads.
Grant
Old 01-04-2025, 01:25 AM   #8
Are you really lugging that thing around with you? There are RunFlat-Tires, marked with ZP (Zero Pressure) or EMT (Extended Mobility Tyre).
997_986 is offline   Reply With Quote
Old 01-04-2025, 11:11 AM   #9
elgyqc's Avatar
Yes.
https://www.youtube.com/watch?v=FRmZKauf644
Grant
Old 01-04-2025, 12:42 PM   #10
Hate runflats. Terrible ride, at least on my Cayenne.
Good thing I checked the spare: 10 lbs!
-H. L. Mencken
