Old 11-23-2024, 11:18 AM   #1
986 rear shelf compartment with sound package '99
Hey,
does anybody know if there is a different part number for the rear compartment shelf thingy if you have the factory installed sound package (6speaker set up)?
I have a crappy subwoofer installed in the middle compartment and would like to remove it and return the storage option.
Or can you just repurchase the doors?
Regards
Dennis
dennisleonardok is offline   Reply With Quote
Old 11-24-2024, 05:07 AM   #2
Registered Member
I can’t see a way that the doors are available, as there is no way to readily replace them. One of mine had gotten stuck a few years back, and I tried to figure out how to access the mechanism. That simply didn’t appear possible without going in a direction which would have caused more damage than it would have cured. I did finally discover that brute force was the answer, at least in my case.
It will probably be your best bet to source a used one and, if needed, add the speaker kit to it.
Tom Coradeschi
03 Boxster
tcoradeschi is online now   Reply With Quote
Old 11-24-2024, 10:03 PM   #3
Alright cheers, there is probably a hole under the whole subwoofer anyways, so I’ll just get a new storage compartment and maybe move the speakers to the new one, I’ll figure something out.
