-   -   Winter Specials (http://986forum.com/forums/boxster-general-discussions/8656-winter-specials.html)
NickCats 12-17-2006 03:18 PM
Winter Specials
I thought those of you in Chicago might be interested in a mailing I got from Joe Rizza Porsche regarding their winter specials :
Comprehensive Vehicle Inspection for Winter : $60.00
Complete Brake Fluid Flush and Fill : $105.00
Four Wheel Alignment : $245.00
Offer expires 12/29/06
Hope this helps someone in need...
Nick
Sammy 12-18-2006 06:57 AM
Thanks for the heads up NickCats!
bmussatti 12-18-2006 07:01 AM
Thanks, NickCats, that seems like a great price for the Brake Fluid change.
Perfectlap 12-18-2006 07:19 AM
$245 for a wheel alignment is typical Porsche BS.
It should not take moret than hour for a trained PCar guy to do a spec alignment.
(figuring your dealers hourly labor rate is $150 per hour TOPS!)
The tech guy has probably done it a thousand times and I doubt your car was seriously out of alignment to begin with.
Its no more complicated aligning a Pcar then it is doing the same for any other sports car.
For $245 they should at least let you sit in it while they do it.
Any speed shop can do just a good a job and save you a hundo.
Sammy 12-18-2006 08:42 AM
For $245 they should have a hot chick to give... SENSORED... :mad:
NickCats/bmusatti, If you need a brake fluid flush give me a call and bring a 6-pack. $105??? Are they nuckin' futs!!! ATE Super Blue can be had for less than $15/can (I bought two cans just to be safe since I was flushing out the old stuff completely).
bmussatti 12-18-2006 08:52 AM
Hey Sammy, I will take you up on this in 2007! When you do the brake fluid, this also does the clutch fluid too...right??
Sammy 12-18-2006 09:01 AM
Yes, the clutch uses the same fluid as the brakes and can be done at the same time. I flushed the brake lines only before I put Nicole up for the winter, but I plan to put her up and do the clutch this spring. I was going to do the clutch but I didn't have a stubby wrench at the time so I decided to wait.
bmussatti 12-18-2006 09:22 AM
Sammy, you crack me up, dude. FYI, my daughter's middle name is Nicole!!
