Old 11-03-2024, 11:30 AM   #1
Coolant Leak at coolant outlet
Hi friends, It looks like I have a coolant leak on the passenger side of the engine, front of the engine. Picture is from behind passenger seat. There is a coolant hose coming out of this flange. I cannot seem to find this part online. Do I remove the flange and replace a gasket, or is it just a sealer, or is this some type of part that should be replaced? Thanks in advance
markosider2 is offline   Reply With Quote
Old 11-03-2024, 12:31 PM   #2
Year and model?
Old 11-03-2024, 01:51 PM   #3
Sorry. 2000 Boxster S
Old 11-04-2024, 05:38 AM   #4
That has a gasket under it, 996-106-326-51
Old 11-04-2024, 01:54 PM   #5
Marco, since you have to remove the accessory belt to replace the gasket that failed, you may want to consider installing a new belt as well..
Gilles is offline   Reply With Quote
Tags
coolant leak
