Old 10-10-2024, 09:48 AM   #1
Clutch cable
Trying disconnect clutch cable which is by firewall , pushing hard and they are not coming off.
Is there any trick to undo them?
Wysłane z mojego M2101K9G przy użyciu Tapatalka
joshua3mm is offline   Reply With Quote
Old 10-10-2024, 10:36 AM   #2
Clutch Cable ?? on a boxster ??
theiceman is offline   Reply With Quote
Old 10-10-2024, 10:51 AM   #3
78F350's Avatar
The tubing is disconnected by using two wrenches, same as the power steering pressure line in this picture:
Old 10-10-2024, 11:29 AM   #4
Thanks , exactly what I did , two wrenches even one for brake cables that it's not slipping and nothing.
Old 10-10-2024, 11:47 AM   #5
a little bit of heat goes a long way ,, try hitting the outer casing with a bit of heat like propane so it will expand a little .
Old 10-10-2024, 11:52 AM   #6
Will try , thanks for the idea.
Btw , the new cable is a joke , over twice more expensive for LHD then for RHD car.
Old 10-10-2024, 01:04 PM   #7
Before you guys totally kill this fitting, try doing it the correct way:
Old 10-17-2024, 12:24 PM   #8
He IS doing it the correct way .. you are talking about removing the fitting from the line, he is just trying to get the line apart. two wrenches, , they can be tight AF
OP did you get the line to seperate ?
Old 10-17-2024, 01:37 PM   #9
Yep, those connectors can be separated using conventional wrenches, but if it's really stubborn and won't budge, better not force it and just get a flare nut wrench set that fits around the whole thing and gives you a better grip:
https://www.amazon.com/DURATECH-3-piece-Vanadium-Organizer-Included/dp/B08FB2N8V6/ref=asc_df_B08FB2N8V6/?tag=hyprod-20&linkCode=df0&hvadid=693284521083&hvpos=&hvnetw=g&hvrand=14307591880238943829&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9031970&hvtargid=pla-1063072767822&mcid=988005e1162a398cb834801b8b861a51&th=1
