Old 09-18-2024, 07:48 AM   #1
ISO - Pin removal tool for factory amp
I recently installed a 6x40w cabrio amp in my car and ran the rear speakers up to the amp. However, I did a shotty job crimping the wires to the new amp pins and one of the wires came loose. So I need to remove the pin and try again. Does anyone know which pin removal tool will work for it? I tried a few Amazon specials and everything is too big or too little ☹️
Thanks!
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
Danimal is online now   Reply With Quote
Old 09-19-2024, 07:12 AM   #2
I do not have a solution, but do you mean that one? Mine was f****up as well, so I am in the same boat.
997_986 is offline   Reply With Quote
Old 09-19-2024, 10:16 AM   #3
Yep, that’s the harness I am having trouble with.
