Old 06-06-2024, 01:04 PM   #1
2.7L vs 3.2L transmission difference
Hello
I have a 2002 Porsche Boxter base 2.7L and need to replace the transmission. I found one in really good condition, but it is listed as a 3.2L engine. Everything I researched seems to suggest that the Auto Tiptronic Transmission should fit both.
The OEM part number is ZF-5HP19FL.
Can anyone help and confirm that this transmission will fit the 2002 Porsche Boxster 2.7L
thank you
Big rig is offline   Reply With Quote
Old 06-07-2024, 12:06 PM   #2
The S has a taller final drive ratio (3.73), while the 2.7 has a final drive of 4.16, so you'll top out at a higher speed in each gear. This means you'll have slower acceleration and lower revs at any given speed.
You'll probably get better fuel economy and a quieter drive, but that's not really why we buy Boxsters, is it?
The 2.5 transmission has a 4.20 final drive, which would make your car a tiny bit more sporty, but I can't confirm if the software for the transmission control will work, you may have to do the legwork for that one.
All in all, I'd try to find out if the 2.5 is compatible, they might be cheaper to buy and would make the car a little more peppy, otherwise go with a 2.7. I wouldn't install a 3.2 transmission, it'll be a noticeable hit to performance.
S50Sinner is offline   Reply With Quote
Old 07-14-2024, 02:31 PM   #3
Send a message via AIM to CoachTyree
Good Information. How about changing the axels , hubs, brakes etc. ?
CoachTyree is offline   Reply With Quote
Old 07-14-2024, 02:33 PM   #4
Putting the 2. 5 in place of a 3.2 6 speed.
Tags
boxster 986 , transmission
