Old 01-31-2024, 12:43 AM   #1
Centre digital display failed
the centre digital display on my 1998, 986 Boxster suddenly went dark at switch on 2 days ago. I've tried the switch off, lock and leave, but no change. I saw something about a 'long press reset'?
Any advice, thanks.
Simon
NEBoxter is offline   Reply With Quote
Old 01-31-2024, 05:27 AM   #2
KevinH1990's Avatar
https://www.youtube.com/watch?v=g1N9TdLCFGo
This video should help. I think that there are two likely sources for your problem:
1. A failed bulb
2. A failed lcd
I think it is most likely the bulb because the display failed suddenly.
You can follow the procedure shown in the video to disassemble the cluster and replace the bulb. If that doesn't resolve the problem, the video shows the procedure for replacing the lcd. The de-soldering and soldering process required to replace the lcd appears to require some skill. You may need to find a speedometer repair shop to perform the work for you.
In the U.S., Palo Alto Speedometer and Hollywood Speedometer are potential repair shops. (I have not used them, but a search should reveal some posts from Porsche owners who used their services.) I expect that you can find a similar service somewhere in the UK.
Good luck.
Old 01-31-2024, 06:19 AM   #3
thanks, and what bulb type required?
Bulb sounds likely, thanks.
I found a good video to remove the cluster:
https://www.youtube.com/watch?v=Ix265ICew4g
and actually a complete description here of the job:
https://www.pelicanparts.com/techarticles/Boxster_Tech/102-ELEC-Instrument_Cluster_Bulb_Replacement/102-ELEC-Instrument_Cluster_Bulb_Replacement.htm
Simon
