Old 01-23-2024, 03:35 PM   #1
Fuel pump sending unit question
Attachment 23581Hi All,
I noticed that I was getting a fuel smell in my cabin when the heater was on. I checked the fuel pump sending unit and do see fuel on top of it. I've order a new sending unit and seal. Pelican's DIY show three hoses on the sending unit. Mine only has two. Am I missing one? I've circled where the missing one might go below. Thanks!
spdrcr21 is offline   Reply With Quote
Old 01-23-2024, 04:57 PM   #2
older cars have a return line, my 03 for example does not. You are experiencing a common problem where the plastic fuel nozzle on the level element ages and cracks and leaks. Good Luck
2003 Boxster S, Chevy LS3.
obthomas is offline   Reply With Quote
Old 01-23-2024, 09:53 PM   #3
Thanks for confirming obthomas
Old 01-27-2024, 05:08 PM   #4
I replaced everything about 2 months ago..easy job...BUT I will caution you on removing the hoses,just my pump was bad and when I was trying to Dis-connect the lines I snapped off the plastic nipple on the fuel sending unit,..So I now have a completely new system Bc I had to replace the sending unit aswell...hardest part for me was seating the new seal...Have fun..
flmont is offline   Reply With Quote
Old 01-31-2024, 08:48 PM   #5
Thanks for the heads up. The hoses were a pain to remove on the sending unit. One of my connectors was bad and would no longer hold onto a nipple. I was able to use a similar Dorman part. It's held up thus far. The seal wasn't too bad. I used a new one and used synthetic grease to lube it.
Old 02-02-2024, 02:02 PM   #6
Welp, that Dorman part doesn't hold too well. It came off after a few day. I've ordered a new fuel pump.
Old 02-03-2024, 11:00 AM   #7
Ahh Now see I didnt think of using grease. I did use a little WD 40..towards the end of my aggravation...LOL
