Old 12-20-2023, 10:57 AM   #1
Nickanator8's Avatar
Wheel fitment question
Hey guys, ever since I got my Boxster I've shifted from looking for Porsches to now looking for Porsche accessories.
I've seen this listing come up a couple of times and I'm curious if anyone else has done this wheel on their 986 already. I'd love to see what they actually look like on the car.
https://denver.craigslist.org/wto/d/denver-set-of-18-staggered-porsche/7697436090.html
I currently have a set of 17" turbo twists that are in desperate need of a refresh. I'm thinking they could be my winter set and these might look good as my summer set.
Ride height is stock, but I do occasionally load up the car with more extra weight than most, see the two kayaks on my RTS in my profile pic.
Thoughts? Any suggestion on tire size with these wheels?
Cliffy, 2000 Porsche Boxster S Tiptronic - The Sportscar Utility Vehicle
Nickanator8 is online now   Reply With Quote
Old 12-20-2023, 02:20 PM   #2
The Radium King's Avatar
996 rear wheels need a significant spacer to fit on the rear of a 986.
Old 12-20-2023, 03:28 PM   #3
husker boxster's Avatar
Here's a handy tool when looking for wheels.
https://www.1010tires.com/Tools/Wheel-Offset-Calculator
1989 928 S4 5 spd - black
Old 02-04-2024, 08:06 PM   #4
Qingdao's Avatar
I can't see the original link, but do the 17" turbo twist wheels fit?
How much more offset are the 996 wheels?
I coulda sworn I've heard of someone putting the 986 rear wheels in the front and 996 rears in the back. I might have been mistaken.
'98 PP13B powered "RX986"
Old 02-15-2024, 07:49 PM   #5
Hi All,
I’m new here, bought my 2001 Boxster S a couple months back and been thinking about upgrading its stock 17 inch wheels since then.
I came across used 981 18-inch ones a few days ago that come with good tires too, but even after checking the fitment in the tool linked here and on another site, I honestly still can’t understand if the new setup is going to work, and what I might still be missing, so would really appreciate input from experts.
Current setup 17”
Front: 7 ET 55; 205x50
Rear: 8.5 ET 50; 255x40
New setup I’m looking to buy 18”
Front: 8 ET 57; 245x40
Rear: 9 ET 47; 275x40
From what I understand, I’ll need 15mm spacers in the front. Is that correct?
Not sure about rear. Anything I should be worrying about in terms of the tires size?
Thank you all so much!
Pashets is offline   Reply With Quote
Old 02-16-2024, 01:35 PM   #6
Originally Posted by Pashets View Post
Hi All,
Current setup 17”
This is my goto site for this stuff: https://www.wheel-size.com/calc/?wheel1=205-50-17X7ET55&wheel2=245-40-18X8ET57&fcl=50mm&wcl=30mm&scl=50mm&sr=0mm
That link has the specs of what you have on the front versus new, and yes, it looks a 15mm spacer would be ideal, as long as the fender still clears.
Here is the rear link: https://www.wheel-size.com/calc/?wheel1=255-40-17X8.5ET50&wheel2=275-40-18X9ET47&fcl=50mm&wcl=30mm&scl=50mm&sr=0mm
It looks like that should work with no spacer.
redpepperracing is offline   Reply With Quote
Old 02-16-2024, 04:41 PM   #7
Thanks a lot! Will go check them out now I think
