Old 11-02-2023, 10:37 AM   #1
RoadHazard's Avatar
"Failure Convertible Top Ctrl." on 987
Following a convertible top repair, my 2005 Boxster S (987.1) now displays "Failure Convertible Top ctrl." whenever I close and latch the top. It's very consistent, not intermittent. Both left and right transmission gearsets have been rebuilt, and the ECU under the left seat has been replaced. The top goes up and down just fine, so it doesn't appear to be a gross mechanical problem.
Another symptom: If I start the car with the top closed and latched, the electric motor starts briefly and attempts to move the convertible top and clamshell slightly. This is similar to the way the car snugs down the top and clamshell when you first close the top, but it shouldn't happen when you start the car with the top already closed. If I release the latch before turning the key, it doesn't do this.
Ideas?
2005 Boxster S
RoadHazard is offline   Reply With Quote
Old 11-05-2023, 11:41 AM   #2
RoadHazard's Avatar
Does your top do this?
Sanity check, please. When you raise your convertible top to the fully closed position and then latch the manual overhead latch, does the electric motor start up again for about 1 second to tighten the top and the clamshell?
My car (a 2005 Boxster S 987.1) does this, but I can't remember if that's normal or not.
2005 Boxster S
Old 11-06-2023, 05:06 AM   #3
husker boxster's Avatar
No, mine doesn't. I'm scattershooting but my guess is you have a bad sensor in your latch mechanism. It's not recognizing the closed position.
1989 928 S4 5 spd - black
Old 11-06-2023, 06:35 AM   #4
RoadHazard's Avatar
Terrific. Thanks for the data point and the suggestion.
Results seem divided about 50/50. Half the people I ask say their car’s top doesn’t move, and half say it does. Weird. I can’t tell if the difference is because of model year or something else.
I’ve checked and rechecked the switch in my windshield and it’s working fine. For example, if I delay closing the latch, the top won’t do its little 1-second tightening maneuver until I do. And my Foxwell OBD scanner shows the switch open/close right on cue.
After replacing the ECU and rebuilding the gear trains I’m running out of ideas…
2005 Boxster S
Old 02-26-2024, 04:18 PM   #5
I found you on RL also ---- did you fix this? what was it?
pcarsrule is offline   Reply With Quote
Old 02-26-2024, 05:38 PM   #6
RoadHazard's Avatar
No, afraid not. Still working on it...
2005 Boxster S
Old 09-06-2024, 10:13 AM   #7
RoadHazard's Avatar
Fixed!
Fixed it!
The problem was an incorrectly programmed RCM (the electronic module under the left seat). ECU Doctors in Florida sent me a bad one, then took it back and sent me another bad one, then took that one back and sent me a good one. That's the short version. It actually took more than a year in total and a whole lot of pointless troubleshooting to discover their fault. I'm not a happy camper.
Moral of the story: Porsche changed the convertible top behavior partway through the production run of 987s, so if you replace your RCM make sure it's configured for your EXACT model year, not just any old 987.1 or 987.2. The model year makes a big difference.
2005 Boxster S
