-   -   Need help finding terminal 31 on relay block (http://986forum.com/forums/boxster-general-discussions/83910-need-help-finding-terminal-31-relay-block.html)
Luckyman01 09-16-2023 11:29 AM
In the Bentley book, page 24-7 Fuel injection, DME Component testing, one of the tests is check for continuity at terminal 31 on relay block.
I cannot find terminal 31.
Can anyone help?
David
Deserion 09-16-2023 12:54 PM
I think that may be a misprint. Terminal 85 on the relay/block is the ground for that circuit. Can’t locate a 31 in the diagram.
Couldn’t hurt to trace that ground to GP8.
Luckyman01 09-16-2023 02:28 PM
I could not find 31 in another documentation either.
I will reverify the ground on that circuit.
78F350 09-17-2023 10:07 PM
It may not exactly answer your question, but on these German cars there is standard terminology for certain circuits. Terminal 31 refers to ground, Terminal 30 is +12V hot at all times, terminal 15 is switched +12V, etc... *So, you are looking for continuity to ground I expect.
http://986forum.com/forums/uploads02...1695013147.jpg
https://en.wikipedia.org/wiki/DIN_72552
Luckyman01 09-18-2023 12:40 PM
Makes sense to me
Thank you for the graphic image.
David
