Old 07-24-2023, 08:25 AM   #1
Steering Wheel (non) Adjustment
Recently acquired a 97 Boxster. I'm unable to adjust the steering column. I got underneath the dash and I can see the pin pushing in when moving the lever, but the wheel does not budge. What's the best plan of attack for getting the column freed up and moving again?
ecruz is offline   Reply With Quote
Old 07-24-2023, 11:12 AM   #2
elgyqc's Avatar
If you are talking about the in/out movement, I think that that adjustment is used so seldomly that the wheels are frozen in place on many cars. I got the wheel on one of the cars I have worked on to move by forcefully yanking and pushing on it, but it was still stiff to move.
Grant
Old 07-24-2023, 11:45 AM   #3
Yep, I'm talking about the in/out movement. I'm constantly trying to move it, putting as much force as I dare, for fear of bending the steering wheel. I've tried tapping the column with a hammer. Although, I admit, there's only a small spot accessible and I don't even know if that's where it moves from. I'm thinking about taking the steering wheel and lower trim pieces off and spraying PB Blaster in every little space I can find. Maybe I'll just have to live with it as it is.
Old 07-27-2023, 07:58 AM   #4
flouese's Avatar
Same problem
Had the same problem. Issue fixed. Read the owners manual for proper operation!
99 Boxster base
1966 912 3 gauge
flouese is offline   Reply With Quote
Old 07-28-2023, 12:14 PM   #5
This is the process I'm trying. Am I missing something?
Old 04-29-2024, 04:08 AM   #6
Not at all patronising!
I have the same issue, luckily with my 30 years of driving experience and owning two previous mid 90s Porsches I know about the lever.
Please point to the part in the instructions that told you how to fix it when the lever moves fine but the wheel does not pull forward.
daboy3000 is offline   Reply With Quote
Old 04-21-2025, 10:29 AM   #7
Where are you seeing the pin move? i have the same issue where its stuck - and can't find a solution!
Mattrsupplyco is offline   Reply With Quote
Old 04-22-2025, 05:19 AM   #8
I've kind of given up on getting mine to move. If you get yours moving, let me know how you did it.
Old 04-23-2025, 03:44 AM   #9
My steering wheel adjustment has never worked on my 2005 SE, but I was inspired by this thread to give it another shot. Yesterday I lowered the adjustment lever and then shook the steering wheel toward me and away with some force, but rattling it fore and aft. Suddenly it moved and now it works. No up and down adjustment, but definitely moves toward and away from me.
N227RV is online now   Reply With Quote
Old 04-23-2025, 10:26 AM   #10
Rob175's Avatar
Fortunately, the wheel adjustment works fine on my 98. I can't speak for other years but mine is ONLY designed to move in/out not up/down too. Instead, for up down I use the seat lever to raise and lower the seat which also tends to move the seat closer or farther at the same time.
With a little trial and error it becomes comfortable and good for me.
98' Boxster
Rob175 is online now   Reply With Quote
