Old 06-15-2023, 07:41 AM   #1
3.2L cylinder 5 seized
My 2001 boxster S seized on cylinder 5. What is the best solution to fix it ? a short block at Porsche is 14000$. Any idea ?
SGtech is offline   Reply With Quote
Old 06-15-2023, 07:57 AM   #2
seningen's Avatar
Realistically -- swap in a used engine. Probably $5k for the engine and $2-3K for the install. (just swagging)
mike@lonestarrpm.com
Old 06-15-2023, 07:57 AM   #3
Easy: Spend lots of $ or go the used engine route..............
Old 06-15-2023, 10:37 AM   #4
elgyqc's Avatar
Do you have the skills to rebuild an engine, or to remove and install one. I am currently installing a used 3.2 in my 2000 S. Where are you in Montreal? There is a place In St-Hubert that may have an engine.
Grant
Old 06-16-2023, 03:37 PM   #5
Assuming that you find a good used engine, is not too difficult to replace it, as long as you take your time to disconnect everything, BTW having a buddy to help = priceless :-)
If you lower the engine and transmission together switch engines and raise them in place at the same time. much easier than removing the engine and leaving the gearbox in place. you can do this with an engine hoist (cherry picker..) that you can buy from Harbor Freight.
Good luck
