Old 06-10-2023, 01:27 PM   #1
Coolant Leak Question
Hello! I have a '98 986 Boxster that was backed into nearly 5 months ago. I brought it to a body shop that has a good reputation and they replaced the passenger side radiator (mounting clip was damaged), fixed the front quarter panel, front bumper, etc. I decided to have the entire car painted while it was in there and just picked up the car after 5 months. The final bill shows a new radiator and coolant.
Driving the car home, the coolant light started flashing and I noticed the coolant was a bit below the min line. The car is way over due to be smogged and because the shop disconnected the battery, I needed to drive it 40 - 50 miles to get the sensors registering before smogging it. I did so and while it was being smogged it started leaking coolant from in front of the rear wheel on the passenger side (US car). Needless to say the smog tech was not happy that the rollers on the machine was covered in coolant.
Further investigation shows that there is moisture at the top of the rear trunk lid and a the top where the cap is was wet. My guess is the body shop had no idea that there is the bleeder valve under the cover in the coolant/oil AOS. What are the thoughts that this was caused by them not removing air in the system vs. something more? Should I simply fill it up with the vent open, warm it up, etc. to purge the air or should I check something else out first?
I should mention that the cap has already been updated to the -04 model
'98 Boxster 986
'87 911 Carrera Cabriolet
elav is online now   Reply With Quote
Old 06-10-2023, 02:02 PM   #2
check radiator fans. they are two speed controlled with a resistor on the fan unit. Could have caused your overheating and fluid loss.
jrj3rd is offline   Reply With Quote
Old 06-10-2023, 03:50 PM   #3
Thanks for the guidance. I checked it out and the fans are working perfectly. I actually bled the system and all seems good. So I guess the body shop doesn't know how to bleed Boxsters...
'98 Boxster 986
Old 06-10-2023, 08:23 PM   #4
When I changed my coolant the light flashed for a few drives while I drove around with the bleeder valve open. The directions say to idle but I felt that was wasteful. I’m not convinced you don’t have a leaking expansion tank. What is your explanation for the coolant leak?
Bush Pilot is offline   Reply With Quote
Old 06-11-2023, 03:50 AM   #5
1998 Boxster Silver/Red
That.
1998 Porsche Boxster
Old 06-12-2023, 12:27 AM   #6
Good luck fixing the leak when it appears again.
