Old 05-29-2023, 04:54 PM   #1
2000 986 & 1972 914
martinef1963's Avatar
Clock/Oil Gauge LED in Instrument Panel Not Working
Hello,
I have a 2000 Boxster, base, 2.7L, that is not displaying the clock/oil gauge led.
I was wondering if anyone can point me to a possible solution. I think I have already asked, but can't find my previous post.
Any help would be appreciated.
thank you,
martinef1963 is offline   Reply With Quote
Old 10-14-2023, 06:31 AM   #2
I don't see any replies so, bit late but here's my two cents. these usually don't go wrong, most likely its the little bulb behind it that failed. you can check if the panel is still working by shining a light on it from the front (with ignition on). you should be able to see the clock or oil gauge working. changing the bulb it pretty easy, lots of info here, on youtube or google.
robucop is offline   Reply With Quote
