Old 04-24-2023, 06:14 PM   #1
Newly purchased 1998 986 making a "whoop" sound occasionally at startup
Hi all,
Just picked up a 1998 986 with 72K miles in Nevada after my 2000 l986 with 103K miles and an LN IMS bearing that I had owned for 3.5 years lost to Tahoe that cut a corner too close.
Test drove and checked out the '98 and all seemed fine: frankly, looks like a museum piece.
Anyhow, after starting and stopping several times and getting it up to operating temperature for a sustained period, it has started to occasionally started to make a momentary what I can only describe as a "whoop" sound that lasts for a second or two at the most. It seems to come from the back of the car/engine compartment, and it sounds to me tike an "air" issues rather than a mechanical one (maybe the oil separator as that seems like a common air intake issue? does the car have an air pump as it sounds a bit like the air pump on my Land Rover D2).
Any idea what this could be?
austinporsche is offline   Reply With Quote
Old 04-24-2023, 07:15 PM   #2
The car does have an air pump but it should only be active for the first minute or two after starting the car.
Old 04-24-2023, 07:25 PM   #3
Motorist & Coffee Drinker
78F350's Avatar
Loose spark plug?
https://986forum.com/forums/performance-technical-chat/77965-986-normal-engine-noise.html
Old 04-25-2023, 03:07 AM   #4
There's two vids in that thread—or at least there's supposed to be. The 2nd one seems to be no longer available. I do some of my own stuff on my car, but I'm certainly no seasoned mechanic, but I don't hear anything much different on the remaining 1st vid than what my car has sounded like for the past 80K miles.
The comment later on about the "chirp" sound is what I experienced with loose plug(s), including the description, by pilot, of hearing it at low revs when blipping the throttle (or briefly on normal acceleration from a standstill). I didn't hear it at all at high revs, and it did go away when I replaced the plugs. (I would have just tightened them, but they were due for replacement.)
Old 04-25-2023, 04:55 AM   #5
On the slippery slope
JayG's Avatar
Where in Austin are you?
If you need a good indy for service, I can give you an excellent recommendation
2004 996 Targa Tip
Instructor - San Diego region
Old 04-26-2023, 03:27 PM   #6
Starter?
https://www.youtube.com/watch?v=MdwZDmZOhKQ
Not exactly sure what Whoop means. Starter going bad has this screech or squeal sound. Just had my 1999 (original owner) 986 starter replaced today.
1999 Boxster - Silver/red (original owner)
2017 718 Cayman S - Black/black & red
Bill in VA is offline   Reply With Quote
Old 04-27-2023, 12:18 PM   #7
seningen's Avatar
I"m halfway between Austin and Dripping Springs if you want someone else to give it a listen?
The Starter is a likely candidate at startup -- sounds like a whirl to me -- before the solenoid disengages.
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
Old 04-28-2023, 02:04 PM   #8
Thanks, all.
To the Dripping-Austin guys, I am out on Bee Cave Road.
I am now pretty confident that it is the starter, so going with that replacment.
Old 05-20-2023, 03:25 PM   #9
Replaced starter, no more "whoop" (maybe more like a whir like some described, like a cable being pulling out of a winch really quickly, probably a more accurate description of the sound).
Pinion gear retraction spring was clearly weaker on the starter I pulled out than on the new starter.
Old 05-20-2023, 03:27 PM   #10
On to the next issue (ambient temp sensor)
