Old 04-17-2023, 05:56 PM   #1
Remove stains on calipers
Any ideas on how to remove my caliper stains without ruining the paint? Brake cleaner doesn’t work, nor does wheel cleaner.
s_wilwerding is offline   Reply With Quote
Old 04-22-2023, 07:58 AM   #2
Rob175's Avatar
That wouldn't bother me but I'm not you....LOL
But IF you are really bugged by it a suggestion:......First order the "Porsche" high heat resistant decals (I found sets on eBay)......then remove the old ones with a solvent or a very light sanding....then re-spray the caliper (mask off everything carefully).......and finally replace the decals.
Do it the right way the first time and they will last for years and years.
(ps. If you ever thought of changing the caliper color NOW would be the perfect time)
98' Boxster
Rob175 is offline   Reply With Quote
Old 04-29-2023, 12:50 PM   #3
The solution I found is Adams hard water spot remover. Long story, but I figured out that hard water remover is similar to wheel brightener, so I figured I’d try. This is the same caliper - not perfect, but a whole lot better.
Old 04-29-2023, 12:52 PM   #4
Sorry, attaching pics from the iPhone is a pita.
Old 04-29-2023, 03:32 PM   #5
I would say that worked really well and make me glad I didn't paint mine yet.
wiebuschk is offline   Reply With Quote
Old 04-29-2023, 07:59 PM   #6
Nicely done!
When i saw the first photo I thought "he's probably stuck with those stains"
2002 Boxster
maxnine11 is offline   Reply With Quote
