-   -   986 windscreen washer tank replacement (http://986forum.com/forums/boxster-general-discussions/83002-986-windscreen-washer-tank-replacement.html)
DrRobin 02-18-2023 01:57 AM
Hi,
Can anyone suggest a guide to removing/replacing the windscreen washer tank, as mine seems to have a slow leak?
Is it a long job or one best left until it’s a bit warmer?
Here is what happens, I fill the tank up and then about 2 or 3 weeks later it’s mostly empty, even if I don’t use the screen wash. I have had a look underneath but there is no sign of it dripping so must only be a small leak.
Ta
Rob175 02-18-2023 08:13 AM
A spray bottle of glass cleaner and a towel in the trunk might be a much easier and cheaper "fix"......just a suggestion.
ike84 02-19-2023 01:07 AM
I had my fluid line disconnect from the tank accidentally and my tank slowly drained from that. Apparently porsche never put a hose clamp on that connection and it slipped right off. It was a quick and cheap fix though.
Sent from my SM-N975U using Tapatalk
