Old 02-12-2023, 05:44 PM   #1
97 Boxster with Intermittent Brown Out
I’ve got a 97 Boxster with 50k mi. with an intermittent electrical brown out condition where the radio resets, car stumbles, lights dim etc. especially when an electrical load is put on the system. I measure 12.6V at the battery during the brown out with the car running. I measure 14.5V at the battery when not in the brown out. I can stop and restart the car and it will usually go away. I’ve replaced the alternator and starter and fuel pump relay with no success. I found rat damage to the knock sensor but who knows what else was damaged by a rat. I don’t see other damage.
Bush Pilot is offline   Reply With Quote
Old 02-13-2023, 06:34 AM   #2
Run a voltage drop test across the primary battery cables; they are known to develop internal corrosion which leads to resistance issues, particularly when warm.
Old 02-13-2023, 08:29 AM   #3
Thank you but I believe that a fault like that wouldn’t show up as an intermittent brown out. Also, the car is an Arizona car and all those connections appear as new.
Old 02-13-2023, 08:53 AM   #4
Don't bet on it. The corrosion issue is internal to the cable, not just at the connections. Porsche has a TSB about it and improved replacement cables because of it. And a voltage drop test only takes about 10 seconds to run.
Old 02-14-2023, 05:29 AM   #5
OK. Thank you. I'll give it a try. That said when you say "primary" do you mean the high current cables from the battery (+) terminal to the alternator and starter? If so, any thoughts on what voltage drop is acceptable? I suppose another method would be to measure the resistance of the cable and compare that resistance to what an analysis would yield for how much resistance should be there based upon the cable gauge, type (stranded/solid) and length.
Old 02-14-2023, 06:18 AM   #6
"Primary cables" = both battery cables.
Acceptable voltage drop.= It should be very little... a few mili amps.
Go to Utube and look up voltage drop tests.
You will see how to do the tests properly and what to expect for voltage drop.
Edit: I said mili amps I ment to say mili volts.
Old 02-14-2023, 06:20 AM   #7
Yes, the primary ones are the large diameter cables. Maximum allowable voltage drop would be about half a volt. Because cable lengths vary from vehicle to vehicle, and their original starting internal resistance is unknown, voltage drop is quicker and more accurate. If you have access to a Power Probe electrical diagnostic tool, it has a built in voltage drop capability.
Old 02-14-2023, 07:48 AM   #8
I can simply make a voltage measurement across the cable with one lead at the battery + and the other at the block where the alternator and starter tie in, located towards the front top of the engine. I don't see this potential fault causing an intermitten issue like I'm seeing though. But it's an easy measurement.
Old 02-14-2023, 08:02 AM   #9
Finding any fault is often just a process of elimination...............
Old 02-14-2023, 11:35 AM   #10
Your issue sounds like a possible bad ground to me.
This video will show you how to test for voltage drop on the ground (negative) side.
https://youtu.be/qdaOSiScEu8
Keep in mind there are multiple ground points on these cars.
Old 02-14-2023, 12:13 PM   #11
This is where the right tool makes your life easier: A Power Probe can do either positive or negative voltage drops from one tool in a couple of seconds.
Old 02-14-2023, 12:23 PM   #12
You just about have me ready to purchase one just to have it in the tool box
Old 02-14-2023, 12:57 PM   #13
Look into them, very flexible and useful tools. We have both a PP Four and a Maestro, both of which are in constant use.
Old 02-14-2023, 01:30 PM   #14
Thank you for the heads up... I will check them out
Old 02-14-2023, 02:30 PM   #15
It could pay for itself quickly when the Porsche Dealer is charging $225/hr for labor.
Old 02-28-2023, 10:02 AM   #16
I found the issue. The battery + cable was wedged very tightly between the hard plastic cable guide coming through the firewall and the battery tray. The sharp edge on the battery tray was occasionally making a bad electrical connection to chassis by cutting through the insulation on the + cable. A good electrical connection would cause the battery to fail catastrophically and there are signs fo that happening in the past. Not sure if this happened during assembly or if it was done by a heavy handed mechanic.
