Old 07-01-2023, 05:21 PM   #1
PLP
PLP's Avatar
2003 Boxster amplifier male plug
A tricky question...
I am installing a AA/CP 2-DIN unit. I need to bypass the OEM amplifier.
Part number 996 645 331 01
I do not want to splice wires, so I thought I would get a male plug (like the one on the amplifier) and simply create a harness. If it was ever needed, I can just disconnect it and revert to previous state.
Any clue what is the plug type?
Like the radio has ISO plugs, maybe the amplifier has a some kind of standard plug as well.
Thanks for help.
Oh, and l looked on eBay and I may just get some used amplifier and just re-use the plug from it.
Yet, maybe there is a cheaper solution, like the plug itself.
Thanks in advance.
P.S.
I looked up a similar question on Renntech.
It seems it is a dead end street.... but maybe something changed over the years.
Current rides: 2003 Porsche Boxster MT (me), 2019 Bolt LT (me), 2015 Audi Q5 (wife), 2008 VW Rabbit (2.5 inline 5, MT, well, for kid... but you now, it is the 5 straight)
Previous: 2014 Fiat 500e, 2016 KIA Forte5 SX, 2016 Fiat 500X, and some old days: Trabant, Fiat 126p...
PLP is offline   Reply With Quote
Old 07-02-2023, 05:53 AM   #2
Motorist & Coffee Drinker
78F350's Avatar
I'm pretty sure that between the Audis and Porsches I've scrapped I have an amp with that connector. I'll check tonight.
Old 07-02-2023, 08:09 AM   #3
PLP
PLP's Avatar
Yeah, that's the route I took... I found a cheap amp on eBay to sacrifice it. 20 bucks is not cheap plug, but much easier to work with than splicing 9 wires.
How much you'd like for yours?
Old 07-02-2023, 07:45 PM   #4
78F350's Avatar
All the amps I found tonight were BOSE with a different connector. Slight chance there's still one like you need in an Audi TT I can look through tomorrow evening.
