Old 01-09-2023, 07:45 PM   #1
Engine noise
Hey All,
I was gonna ask around for opinions for the engine noise I was experiencing, so I made a video about it. But, before I uploaded it I found out what was going on. I`m sharing it anyway, just for the ones who run into the same problem:
https://youtu.be/9e6TqgnNqUs
To me it sounded like a "metal grinding intermittently on metal" noise, but I was totally wrong. I removed the belt but it didn`t go away. It comes on only when the engine is warm, stops when I hit the accelerator and its frequency is ~400/min, exactly half of the rpm at idle, which is a great hint
It was (highlight the following text by clicking and holding down the left mouse button if you don`t want to guess): loose spark plug
Old 01-10-2023, 06:05 AM   #2
1998 Boxster Silver/Red
Hey All,
It was (highlight the text if you don`t want to guess): loose spark plug
Sounded expensive.
Took me a second to figure out the "highlight the text" clue but, when I did, my guess was correct. And... I was correct only because over the years of reading posts, the topic has come up many times: spark plugs.
Good catch! Easy fix.
1998 Porsche Boxster
Old 01-10-2023, 07:53 AM   #3
Sounded expensive.
I added more detailed instructions
Yeah, I got lucky, I was prepared to drop the engine and tear it down Not that I won`t have to pull it because of other issues
Old 01-10-2023, 11:36 AM   #4
Dude, you have your car pointed down a sloped driveway with the rear jacked up....
I'm not posting this to pick on you (I'm sure you've done it a hundred times before) but to guys who are just getting started - PLEASE DONT EVER GET UNDER A CAR THAT IS JACKED UP LIKE THIS.
Sorry, I had to....
Sent from my SM-N976V using Tapatalk
Old 01-10-2023, 11:58 AM   #5
Sorry, I had to....
Yeah, I hate when people passing by watch me lying under the car DON`T EVER DO THIS AFTER ME! AND ALWAYS BLOCK THE FRONT WHEELS!
