Old 11-08-2022, 11:51 AM   #1
ECS Coil overs
Hi All. I purchased and had installed the ECS Coil overs. They dropped the car quite a bit , so not to bottom out, the installer set the softness to max and spring pre-load to the tightest available (all the way to the top). As a result, the car now bounces over smallest of bumps. Has anyone installed the same coil overs and if so, what settings did you use? Please help.
2000 Boxster S (986)
De-snorkeled withK&N Cold Air intake
Short Shifter 14mm spacers F&B
Secondary Cat delete
Top Speed Test pipes and Exhaust
NJBoxster2000 is offline   Reply With Quote
Tags
ecs coil overs
