Old 09-17-2022, 01:17 PM   #1
Right side turn signal
My right side turn signal front and back as well as
Dash arrow light quit all of a sudden. Checked B6
“Direction indicator light and it was good. Changed flasher
no change……. Any suggestions?
Dave
1998 Boxster
1978 R100RS BMW Motorcycle 140K, 1 owner
WhiteyII is offline   Reply With Quote
Old 09-18-2022, 08:07 AM   #2
No ideas at all? I’ve read about a lot of problems an ignition switch can cause? Like I stated on day all was fine, the next it didn’t……… stalk switch in column?
Dave
1998 Boxster
Old 09-19-2022, 11:28 AM   #3
Found it thanks for the help!
Dave
1998 Boxster
Old 09-20-2022, 04:17 AM   #4
1998 Boxster Silver/Red
Love it.
Listen... what did you find? What was the fix? That's what we do here.
1998 Porsche Boxster
Old 09-20-2022, 06:20 AM   #5
Thanks I posted on Rennlist as well here is my response…….
Torca you were/are right on on your diagnosis. I pulled the steering wheel yesterday to find the wiring plug on left side of stalk was very loose . I plugged it back in and everything worked! There is a plastic guide teet on the stalk switch assembly that would accept a small screw so I installed a small screw to hold the plug secure. It worked great!
Thank you very much for your willingness to help, and share your knowledge it’s much appreciated
Dave
1998 Boxster
