Old 08-07-2022, 06:07 PM   #1
boxster brake question
i have a 1984 alfa romeo spider..undergoing an engine conversion...i am upgrading the oem brake to 12.19 vented disk 2 peice type on all 4 corners..but i am also using the calipers( 4 ) from a boxster.. the oem ( alfa romeo ) master cly will push the fluild i need to stop the car.. so i am/ have installed a master brake cly from( new ) 2000 boxster.... no power boost...no room for it.. so have any of you disconnected the power boost from your system and stopped the car..my spider weighs in at 2380 pounds
anyone can buy a ........ , only drivers drive a ALFA ROMEO..
ALFAROMEO1 is offline   Reply With Quote
Old 08-08-2022, 06:12 AM   #2
do you mean stopped it using the brakes or a tree or the car in front of you?
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 08-08-2022, 06:44 AM   #3
The Boxster master cylinder is designed to be supported by the vacuum booster; it will not work well without it.
Old 08-08-2022, 07:10 AM   #4
most modern car are designed to run with out a booster..my alfa rpider on oem brakes did also,, but i disconected the hose and pluged it,, and it worked fine,,just a little more leg on it
