Old 08-02-2022, 04:14 PM   #1
Oh oh
Car was running hot after i bled the coolant and added some..it wss 96 degrees here.
On my way home from the gym thevtemp started moving up..oil light came on lots of white smoke....am i screwed?
Being towed now.
Sent from my SM-G991U1 using Tapatalk
alansdavid is offline   Reply With Quote
Old 08-03-2022, 02:41 AM   #2
Does your oil look like coffee with creamer in it? If so, yes.
Woody
Old 08-06-2022, 08:58 AM   #3
Jager's Avatar
Being towed now.
When replacing coolant in these cars you need to use an air lift vacuum system or similar:
https://www.amazon.com/UView-550000-Airlift-Cooling-Checker/dp/B0002SRH5G/ref=asc_df_B0002SRH5G/?tag=hyprod-20&linkCode=df0&hvadid=312174136943&hvpos=&hvnetw=g&hvrand=15332782250118887666&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9031753&hvtargid=pla-435688359104&psc=1&tag=&ref=&adgrpid=63790029762&hvpone=&hvptwo=&hvadid=312174136943&hvpos=&hvnetw=g&hvrand=15332782250118887666&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9031753&hvtargid=pla-435688359104
Hopefully your issue is not serious.
Jäger
300K Mile Club
Old 08-06-2022, 09:26 AM   #4
piper6909's Avatar
You don't NEED that.
There are many on here who have done it without that. I replaced my water pump and didn't use any special tools. I remember jacking up the back as high as possible when filling it and running it with the bleeder valve open for a while. I don't remember the exact steps, but the procedure can be found on here.
2010 Subaru Forester
Old 08-06-2022, 09:38 AM   #5
1998 Boxster Silver/Red
Hi Pipe!
Like you, I replaced my water pump and thermostat, and coolant. I opened the bleeder cap...and several times drove down a nice steep hill next to my home. Good or bad... I left the bleeder open for a few days while keeping an eye on the coolant level. Never had to add any then, nor since.
However... if I had a compressor, and the space to store it, likely I'd get that accu-appliance. When doing the math... I simply don't swap coolant enough to need the device.
Made that mistake with my whatever-brand-name brake bleeder. Worked great, but has been sitting for better than a year waiting for the next brake fluid replacement.
Cheers!
1998 Porsche Boxster
Old 08-06-2022, 09:42 AM   #6
Same! I'm sure vacuum method would be great but I simply opened the bleeder and kept an eye on fluid levels for a few days....
dghii is online now   Reply With Quote
Old 08-06-2022, 09:51 AM   #7
Jager's Avatar
Just depends on how many days you are willing to drive with air pockets in the system.
Jäger
300K Mile Club
Old 08-07-2022, 04:11 PM   #8
piper6909's Avatar
Hi Pipe!
Cheers!
Hey Starter! It's been a while. I hope you've been well. IIRC, I got the idea of leaving the bleeder open from you. And someone else mentioned jacking up the back as high as I could when filling it.
Old 08-08-2022, 03:18 AM   #9
Hey Boss.
I forgot that step... jacking up the rear. Yup
