 Check brake light warning - When brake light works fine?!? Hi there Wondering if any of you have had this issue? Not only do I get the warning but it keeps pinging to remind me to check the brake light. This would be fine, but the light works fine. i replaced the bulb, just in case and keep clearing the fault code, but the warning and pinging persist. My ride is a 987 base model Thanks |
 Thanks Hi Gilles, Thanks, I'll look into that. But if it were pads I'd imagine it wouldn't say "brake light" ? Cheers |
 which bulb did you replace and with what?  You have 3 brake lights |
| All times are GMT -8. The time now is 07:42 AM. |
