Old 07-11-2022, 04:58 AM   #1
Shacky
Windows won’t close all the way after raising top
My Boxster has been dormant for about 3 months. I took her out with top down and after putting top back up the windows remained in the top lowering/closing position and 3/4 closed. Had to lower and raise top again and then windows closed properly.
I’m assuming there’s a micro switch that’s dirty or going. Can someone tell me how I can diagnose/fix?
shacky is offline   Reply With Quote
Old 07-11-2022, 11:20 PM   #2
Unlatch the top. Insert your finger into the hole where the hook goes into. If you press on the tab you should hear two audible clicks corresponding to two separate switches. The second click is responsible for telling the top control unit that the top is closed, permitting closing the windows. If you can`t hear the second click, probably the switch is broken. If you hold the tab in the upper position and now you can roll up your windows the hook does not press on the tab enough to operate the switch in the closed position, you might need some adjustment or replacement. Note that this is for the early Boxsters, the newer ones have one switch only if I`m not mistaken.
Old 07-12-2022, 01:50 PM   #3
Put key in door, turn and hold. One way will roll windows up & other will roll them down.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 07-14-2022, 02:32 PM   #4
Is the top dash light on or off,?
Sent from my SM-G991U1 using Tapatalk
alansdavid is offline   Reply With Quote
