-   -   Radiator fan resistors (http://986forum.com/forums/boxster-general-discussions/82256-radiator-fan-resistors.html)
ike84 05-07-2022 07:31 PM
For tonight's dumb question...
What exactly do the radiator fan resistors do? Are they actually resistors? Why aren't the fans just powered straight from a 12v source?
Sent from my SM-G970U1 using Tapatalk
78F350 05-07-2022 09:31 PM
I've forgotten all I used to know about PIE and EIR, but in simple terms that I can still understand; Yes they are actual resistors and they enable the low speed fan function by making the electricity going through them get tired.
When they go bad, if you run the fan without them by joining the wires it's on high speed only. Replace them with a 100W .5 Ohm resistor
elgyqc 05-08-2022 06:41 AM
Originally Posted by 78F350 (Post 646395)
... function by making the electricity going through them get tired...
... lol...
ike84 05-08-2022 03:42 PM
Ahhh, gotcha!
Here's a fun fact that I discovered while contemplating cools mods last night.....
Our radiators are the same size as those on a Polaris RZR!
I am going to eventually need to up my cooling game and am loathing the process of bumper modification, piecing together the gt3 parts so that I'm not creating additional updroce from a poorly angled setup, yadda yadda..
So I got to thinking - why not just remove the radiator fans and put a second set of radiators in their place? Stacking radiators isn't perfect, but it would be far more cooling surface area than the center rad addition. But thenen of course you have to buy 986/996 rads, either OEM or csf, and neither are cheap.
And then it hit me - just Google 14" radiators! And wouldn't ya know, the RZR rads are nearly identical in size, use the same 1 3/8 hose barbs in the same locations, and you can get a triple row (compared to OEM single row or csf double row) for $100 a piece! That's a hell of a deal in my opinion, even if some minor fabbing is required to get them mounted.
RupturedDuck 02-13-2024 08:51 AM
Unable to start a new thread so please excuse the hijack..!
When our 986S (2000) went for its MOT last year, during the emissions test, the car overheated and launched its coolant over the workshop floor. The cooling fans are not coming on.
Having jumped the relays, the left/slow does not come on, but left/high speed, right/slow and right/high speed all activated the fans.
The AC does not make the slow speed fans come on, however the AC needs regassing, but we suspect there’s damage to the condensers, so not sure if that will have an impact?
Would changing the ballast resistors potentially work or does anyone have any advice to offer? I’ve tried a forum search so if there’s a thread I’ve missed, please point me in the right direction!
elgyqc 02-13-2024 08:03 PM
The left/slow not coming on sounds like the left resistor is bad. As to why the fans don't come on unless the relays are jumped would obviously seem to be bad relays.
RupturedDuck 02-13-2024 11:57 PM
4 relays on the shopping list then! Thank you
Starter986 02-14-2024 03:49 AM
Bad relays... or not.
When my left fan quit working I simply hooked the two wires up to a 12V source. It didn't turn on. Bad motor on the fan. A new relay wouldn't help. I ended up replacing both fans for good measure.
May not be the relays. Test the fan directly before installing those "electrical" items... subject to return. Good luck.
RupturedDuck 03-17-2024 06:05 AM
4 relays and 1 ballast resistor changed. All good now
Smitty2001 05-10-2025 02:16 PM
A/C fan operation
I need a clarification. Both A/C cooling fans don't work at low or high speed. The 2 fuses and the 4 relays are in working order after testing Therefore I believe it is the fan resistors or the fan motors or both. I am planning on changing the resistors with the hack (change the resistors with a new resistor 0.5 ohm/100W). Is the resistor's function to increase the speed of the fan when the engine temp reaches a certain temperature? If this is true, will the fans work at low temp even with a bad resistor?
Petecomplete 05-11-2025 02:45 AM
No. The resistor brings down the effect/voltage to the fan, and makes the fan run slower. The higher the resistance, the lower the effect/speed the fan gets. If you remove the resistor from the circuit, the fan will run at full speed no matter what.
Basicly the fan is connected with two circuits. At first the low speed circuit with the resistor is activated at a given temp (or with AC on), if temp increases more the high speed circuit (without reistor) is activated. So to sum up, if your resistors are broken, the fans will not run with AC on, or when they should run low speed. They will only come on at high speed when the engine gets really warm (around 96C i think)
A cheap generic 0.5 ohm 100w resistor works perfectly. Changed mine 5 months ago. Very easy fix.
