Old 04-12-2022, 06:37 AM   #1
De cat 986 issues ?
Hi there.
Both my silences have holes in now. I’m not sure if I should just replace them or maybe De Cat them. They look like cherry bombs so I assume they are the catalytic converters.
My question is if I D - cat the exhausts will it still pass the MOT and is there a plug-in to let the system now things are okay, so I don’t get a constant engine fault code?
colacharlie is offline   Reply With Quote
Old 04-12-2022, 06:49 AM   #2
you will need to replace them if you want to pass MOT. If in doubt, call a local inspection station.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 04-13-2022, 08:29 AM   #3
Administrator
Im not sure about on the Boxster but generally on most modern vehicles you have up-stream and down-stream oxygen sensors.
Meaning one sensor reads before the cat converter and another reads after it.
If you remove the cat, both sensors will get the same reading which can sometimes flag an issue to the computer that the converter is faulty which will lead to not passing MOT
Sometimes there are ways around this but likely none of them would be deemed legal by your local MOT inspector.
-Matt
Matt at Pelican Parts is offline   Reply With Quote
Old 04-01-2023, 01:23 AM   #4
Hello.AmeerM's Avatar
Depending on the MY of your car, if your car is running RoW dme programming, which I assume it is because of your use of MOT, your secondary O2 sensors should already be ignored by the DME. Therefore decatting should not throw a code.
Can you start the car without pressing down on the clutch? If so, you're most likely RoW
Hello.AmeerM is offline   Reply With Quote
Old 04-03-2023, 09:19 AM   #5
MY 03-04 Boxsters have warm up cats (upstream) and exhaust cats (downstream).
safesaxbdd is offline   Reply With Quote
Old 04-08-2023, 03:33 PM   #6
I suggest boxsa.net as it is UK based and those that answer there will be more knowledgeable about the MOT issues.
