Old 03-19-2022, 09:47 AM   #1
gman1113's Avatar
Help with code
Can anyone tell me what the code P1117 is?
Any help appreciated
gman1113 is offline   Reply With Quote
Old 03-19-2022, 11:38 AM   #2
You never said what year and model, which is ALWAYS critical for code definitions.
Depending upon the above, it may be the O2 sensor heater on bank #1 ahead of the main cat.
Old 03-24-2022, 09:18 AM   #3
FoFoJoe
FoFoJoe's Avatar
following out of curiosity. Year and trim OP?
2001 Base 2.7l, 5-speed (124k) - LN IMS kit
- TopSpeedAuto exhaust (headers/mid/muffler)
- 997 Carrera III wheels w/ECS spacers 18x8 +15mm/18x10 +18mm, Eibach springs
- FunctionFirst shift knob/short shift kit
- Focal speakers/Alpine amp/Kenwood deck/Pioneer 8" subs
FoFoJoe is offline   Reply With Quote
Old 03-30-2022, 02:02 PM   #4
gman1113's Avatar
Year is 2000
Boxster S 98k miles
Old 03-30-2022, 03:42 PM   #6
Originally Posted by gman1113 View Post
Year is 2000
Boxster S 98k miles
OK, P1117 is the code for a heater failure on the O2 sensor ahead of the cat on bank #1. Diagnostics are to check the heat circuit on that sensor for resistance (should be 1.8- 2.5 ohm), a short to ground, or no voltage. If everything is OK, replace the sensor.
