Old 03-15-2022, 11:13 AM   #1
01 Boxster instrument cluster not working when it is cold
My 01 Boxster instrument cluster does not work during cold weather.
The gauges flicker on and off as it gets warmer and then stay on.
This is only a problem during cold weather
Any ideas?
GAS01Boxster is offline   Reply With Quote
Old 03-16-2022, 08:36 PM   #2
KevinH1990's Avatar
http://https://www.youtube.com/watch?v=z4cB7HQDAvo
You could disconnect and re-seat the electrical connectors that transmit power and data to the cluster. While you have it apart you can check for visible problems such as water damage. Do you know whether anyone has removed the cluster?
Old 03-20-2022, 05:40 AM   #3
The electrical harness connections to the cluster are notorious for getting brittle with age and breaking.
Woody
Old 04-04-2025, 10:51 AM   #4
What is the solution to the electrical harness breaking?
01 Boxster S 6Spd, Speed Yellow w/84k miles. | 991.1 911 C2 7spd Manual | 01 996 C2 -6spd - Green Machine - My baby | 997.2 C2S 6spd | 2x 01 Boxster base
professorman is offline   Reply With Quote
