Old 03-04-2022, 08:16 PM   #1
Troubleshooting Rear Window Defroster
Hi there!
The top has been replaced several years ago by the PO and it included the glass window with the defroster wires in it. However when powering up the switch on the dash, the switch light comes on but the window does not defrost. I hooked up a voltmeter to the drivers side window connection and it read 11.80 volts, but taking the same reading on the other side of the window (passenger) it reads zero. Should there be a voltage reading on that side? If yes, where might be the issue?
Thanks in advance for any assistance.
Be good,
Kevin
sailer22 is offline   Reply With Quote
Old 03-05-2022, 07:44 AM   #2
Rob175's Avatar
I assumed you un-plugged the connector that plugs into the glass and tested the voltage? I assume you checked that the painted on heating wires are not scratched or look broken? Check fuse too, even though the light lights the fuse could also be blown. It's a very simple system, kinda like a toaster.
98' Boxster
Old 03-05-2022, 08:35 AM   #3
best thing to do would be to check continuity of the defrost panel. Many youtube videos on how to do this. It's no different then any defrost on any car. Suspect you have a break in the lines somewhere on the glass.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 03-05-2022, 03:03 PM   #4
Yes I did. And again today based on the advice I took off both leads to the glass and had a perfect 11.95 volts which leads me to believe it is somewhere on/in the glass.
Old 03-05-2022, 03:04 PM   #5
Thanks, I will do some research on youtube to see if I can find a fix.
