Old 01-14-2022, 06:59 AM   #1
Psm, abs, and brake fluid lights on
My car died on me the other day. Turns out my battery was bad so I replaced it. I still had a bunch of lights on the dash including the battery light. I replaced the alternator yesterday and now the PSM, ABS, and brake fluid lights are still staying on. What is causing this? Any help is greatly appreciated
blvsmith is offline   Reply With Quote
Old 01-14-2022, 08:38 AM   #2
Without a scan for codes, anything would be a guess.................
Old 01-14-2022, 01:44 PM   #3
I had a reader on it today and it is not showing any codes
Old 01-14-2022, 02:19 PM   #4
You need a Porsche specific diagnostic tool..............
Old 01-14-2022, 06:01 PM   #5
78F350's Avatar
The PSM and ABS are sensitive to low voltage. The bad battery probably triggered the faults.
For quick troubleshooting I often search with a few key words related to the problem and add, "JFP in PA" in to help filter results.
PSM ABS warning light on 996 turbo. - Pelican Parts Forums
PSM Question
Old 01-15-2022, 08:28 AM   #6
Usually the PMS and ABS lights turn off by themselves after you drive the car for a while, it seems that the car computer needs to verify first that everything is working properly..
Old 01-16-2022, 03:33 AM   #7
1998 Boxster Silver/Red
Brake fluid light? What am I missing, here?
1998 Porsche Boxster
Old 01-17-2022, 02:55 AM   #8
Great info thank you I'll do some driving this week!
Old 01-17-2022, 01:09 PM   #9
bcrdukes's Avatar
In addition to driving your car, it would be wise to connect your battery to a charger as not to stress your new alternator. Trickle chargers are a small investment and go a long way.
2001 Porsche Boxster S
bcrdukes is offline   Reply With Quote
Old 01-18-2022, 04:48 AM   #10
Ok good idea I will
Old 01-18-2022, 06:01 AM   #11
JayG's Avatar
Yup. There is a sensor in the fluid tank to monitor fluid level
