Old 01-12-2022, 01:18 PM   #1
One More Parasitic Battery Drain Problem
My battery was discharging in 3 days. When I connect my meter, with the fuse for the door lights removed, I get a click from the radio amplifier and a reading of 1.75 amps. I remove fuse D8 and it drops to .06 and no more click. The red light on the radio is off.
There is no sound from the door speakers.
Any ideas would be appreciated!
dragonflyoh is offline   Reply With Quote
Old 01-12-2022, 06:02 PM   #2
Assuming d8 fuse in yours is the sound system, you likely have a ground short in your head unit. I don't know about the earlier models, but the amp in my 00 didn't have a constant power source but the head unit does. I would start by disconnecting it and replacing the fuse. If your voltage draw is gone, you have your answer.
Sent from my SM-G970U1 using Tapatalk
Old 01-12-2022, 06:18 PM   #3
factory or aftermarket radio? factory speakers? If the key is off the radio shouldn't be drawing anything over about .2 amp.
you also dont say what year the car is so d8 could be radio/amp or it could be the spoiler. https://knigaproavto.ru/shemy/en/porsche/boxster/360-19962004-porsche-boxster-986-fuse-box-diagram.html
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 01-14-2022, 04:23 AM   #4
Thank you for the help.
I disconnected the amplifier and the current flow, with the fuse installed, goes to normal, .2 amps. Time to look at options. Again thanks for the help.
Old 01-14-2022, 05:29 PM   #5
Doesn't that imply that the amp is not on a circuit that is switched?
Prior '70 914, '99 986 Boxster, '01 Boxster S
