Old 11-15-2021, 04:46 PM   #1
Tinted my tail lights (Peel Coat)
So I came across a guy that did this and it allowed him to peel it off if he chose to do so ( warning:I didn't try to peel it off, do this procedure at your own risk). I ended up with 3 coats of the Peel Coat first( barely does any tinting,but supposedly allows removal), then 2 coats of Nite-Shades and finally 3 coats of the Peel Coat gloss clear(maybe an enamel paint for the gloss would make it shinier?). I also Plasti-Dipped the emblem and painted the "S" red to add a bit more to the rear. I think it came out pretty good and thought I would pass it on... Rich
spitfun is offline   Reply With Quote
