Old 11-10-2021, 09:56 AM   #1
DrRobin's Avatar
Uneven at idle and low revs
Sorry for the long post, I hope all of the detail points towards the real problem as I feel I have been skirting round the issue. 2001 986 2.7L with 93k miles
This has been on-going for a couple of months now and I have been through a few things as follows:
- Serviced at my local indy as normal in May. The water pump went when the garage reved the engine to get it through emissions. No other problems.
- Over-heated in a traffic jam in middle of a hot June day. Turned out to be an old expansion tank filler cap, replaced and no further problems.
- Late June, noticed there was something blowing from the exhaust, tracked it down to a hole in one of the CATs.
- Early August, New CATs fitted at local indy, ran okay away from the garage, but a couple of days later I got O2 age codes on all four O2 sensors and then later a misfire. To be fair some of the O2 codes might have already been there as my code reader didn't identify the post CAT codes.
- New O2 sensors obtained and fitted, late August by me. They took ages to arrive and I could only get generic Bosch sensors (correct sensor), so spliced them in to the original connectors using the crimp connectors which came with them. O2 codes gone, but I still getting a random misfire.
O2 outputs look fine, pre-CAT move up and down, post CAT fairly stable.
- Sept, random misfire continued until I realised the battery was very low, charged up and no misfire. My CTEK battery sense said the battery went down to 8V whilst the garage were changing the CATs, I guess they left the key in the ignition over-night and drained the battery.
- Also cleared the ECU.
- Sept/Oct, no misfire recorded but uneven at idle and low throttle openings. Cleaned throttle body, small improvement.
Removed oil cap, ran very rough.
Checked coils, all six had a small crack, so replaced all 6 with Beru.
Plugs looked okay, may be slightly rich/unburnt fuel, but replaced.
- Oct, Long term fuel trims have settle down to about -4% on bank 1 and -5% on bank 2. Short term fuel trims look fine.
- Nov, uneven running at idle and low revs continues. I have just bought a new air filter as the old is okay, but a bit old. I will also have a look at and clean the MAF sensor.
This all started when the CATs were changed, I didn't notice any problem before. The O2 sensors were probably on the way out before the CATs were changed and in hindsight probably should have been changed with the CAT as swapping them over finished them off.
If it turns out not to be the air filter or MAF then I suspect the O2 sensors, even though the graphs from them look fine.
Could O2 sensors cause uneven running?
Is there anything else I should check?
Ta
DrRobin is offline   Reply With Quote
Old 11-10-2021, 12:21 PM   #2
1st....get the correct o2 sensors. You can get them on Amazon. Using the generic ones that crimp are known to cause issues.
Also, it helps to post the actual codes that are in the computer.
how many miles on the plugs?
What are you using to get the fuel trims? Standard obd readers are going to most likely give you the wrong pid for those and not be correct. Seen it myself using Torque. Correct ones can be seen in durametic/pwis. Fuel trims are going to be a symptom of your issue so I wouldn't bother looking at them for now, deep rabbit hole there.
With what you describe it sounds like an O2 issue and/or a vacuum leak.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 11-11-2021, 01:27 AM   #3
DrRobin's Avatar
Thanks for the reply, some further information:
The generic sensors were all I could get at the time and that wasn't easy. I have now found a UK source for the correct ones and since all these problems started when the CATs were changed O2 sensors are the most likely culprit.
There are no fault codes stored. Prior to changing the O2 sensors I had 5 codes, two for pre-CAT O2 ageing, two unknown or vendor specific (turned out to be post-CAT O2 ageing) and a final unknown which was engine bay fan low voltage. Apparently this comes up if the battery voltage was low, which it was.
A couple of months ago when I had a random misfire and CEL, these would show up, but nothing since.
Plugs were changed with the coils, 2 weeks ago, so only 200 miles.
I have Torque Pro installed in an Android Head Unit and an Autel, both show the same for fuel trims, O2 sensors and pretty much everything else I can monitor. After a battery reset all fuel trims reset to 0% and the long term fuel trims then go negative from there. The old plugs confirmed it was running rich.
Is there an easy way to check for vacuum leaks? I have had a look round the vac lines and listened around the intake, but can't hear anything. The vac gauge on my scanner looks normal, but may be a small leak wouldn't show up?
Old 11-11-2021, 01:49 AM   #4
your obd scanners wont show a vac. there is no vacuum pid for porsche. what you are seeing is some math that is being done based on a couple things but it wont be true vacuum.
Watch some youtube videos there are few on checking for vacuum but I think your issues will go away with real o2 sensors.
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 11-11-2021, 02:50 AM   #5
DrRobin's Avatar
Thanks.
4 x Bosch O2 Sensors with correct plug fitted ordered for delivery tomorrow. I will get them fitted on Saturday, together with the new air filter and if it needs it MAF clean.
Hopefully we will then see what happens.
Intake manifold pressure is PID 0B (hex), I thought all vehicles had this, but that must be wrong.
Old 11-13-2021, 10:37 AM   #6
DrRobin's Avatar
4 x Bosch O2 sensors fitted, the post cat on bank 2 wouldn’t thread in, so I had to take the cat out and fit it on the bench, still done now.
ECU reset and then started, ran okay, but not really much different to before, a slight uneven exhaust note. The short term fuel trims went straight down to -8% and I noticed the MAF read 6.5% at 800 rpm when warm. I suspect my MAF is over reading, as the engine was running rich.
The bolts holding the MAF in place won’t come out, my security Torx bit won’t go in correctly, I am not sure if it because the bolts are rusty or the Torx is the wrong size. I was using a security T20 with six stars. I think it might be a 5 stars?
I didn’t manage to get it out, so fitted the new air filter and disconnected the MAF, the fuel trim was much closer to 0% and the engine ran much better. A short journey proved it, running much better and fuel trims close to 0%.
I will try to get the MAF out tomorrow, then try a clean, but probably need a new MAF.
Old 11-15-2021, 11:06 AM   #7
When you disconnect the MAF the system defaults to open loop. There is no fuel correction (trim) happening while in open loop operation. That is why your fuel trims show close to 0%. Fuel trims mean nothing in open loop operation.
What is your MAF voltage with key on engine off??
What is your MAF voltage with engine running at idle?????
Have you disconnected your battery or had a low or dead battery in the recent past????
You say you reset the ECU... what did you do to accomplish that??? What do you mean by you reset the ECU???
Old 11-15-2021, 01:14 PM   #8
DrRobin's Avatar
With the MAF sensor disconnected the fuel status still said closed loop using O2 sensors and short term fuel trim still varied by a few percent, it was just a lot closer to zero than with the MAF connected.
As I understand it fuel trim is set by the pre-CAT O2 sensor and if the MAF sensor is disconnected the ECU reverts to the inbuilt map for air flow. The MAF sensor fine tunes the air flow to control emissions.
I didn’t measure MAF voltage, my reader gives g/s, it was zero with the engine off and 6.5g/s at idle.
I disconnected the battery for 10 minutes to clear the ECU as recommended when replacing O2 sensors.
Regarding ECU bolts I knew they were Torx T20 security bolts and had a driver, but the security Torx we use here are 6 point and Porsche used an unusual 5 point, I have the correct TS20 5 point coming tomorrow.
Robin
Old 11-15-2021, 02:56 PM   #9
[QUOTE=DrRobin;643425]With the MAF sensor disconnected the fuel status still said closed loop using O2 sensors and short term fuel trim still varied by a few percent, it was just a lot closer to zero than with the MAF connected.
Robin[/QUOT
Whenever you disconnect your battery you need to recalibrate your E-gas throttle.
The idle and low rpm issues your are having often happen after a battery disconnect.
You could also have a faulty MAF sensor, but I cannot tell if it is faulty without voltage readings.
Old 11-15-2021, 03:28 PM   #10
DrRobin's Avatar
[QUOTE=blue62;643426]
Robin[/QUOT
I did a throttle calibrate but it made no difference. I will try to get MAF voltage readings tomorrow. Hopefully my 5 point T20 Torx will turn up and I can get the MAF out for a look and possible clean.
By the look of the screws the MAF has never been changed and I haven’t seen it on a bill for the 14 years I have had the car so it stands a good chance of been faulty, especially at 93k miles. A new Bosch MAF is £90, so not too bad if it fixes the problem.
Old 11-15-2021, 12:33 PM   #11
the maf screws are a security torx bit which has a hole in the middle
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 11-15-2021, 03:32 PM   #12
did it have a k&n filter previously? If not, doubt the maf is the issue. If it isn't throwing any maf codes I wouldn't bother with the maf.
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 11-18-2021, 03:53 PM   #13
I was going to add that some of the things we may ask about or have you try might not work for you since you have a ROW car.
for LTFT I would just check it every now and then for a bit and see how it trends. Might take some good drives to see any difference.
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 11-19-2021, 01:20 AM   #14
DrRobin's Avatar
RoW - Rest of the World?
My chassis number decodes as
WP0ZZZ98Z1U6XXXXX
W - Germany
P - Porsche
0 - Sports car
ZZZ - Europe/RoW
96...6 - 986
Z - Europe/Row
1 - 2001
U - Uusikaupunki Valmet factory (Finland), Boxster 97-2010
So strictly it is Europe/RoW, but I see that you are distinguishing between US and RoW.
Fuel Trim
The fuel in the UK changed from E5 for regular unleaded (95 RON) to E10 this summer, unfortunately for me that also coincided with the CAT and O2 sensor changes and the start of my problems. We can still get E5 premium unleaded, Shell V-Power (99 RON), I have never really used it, I did try a tank a month ago, but it made very little difference. Perhaps now it is running better, I would notice the difference.
E10
I think I have got the LTFT wrong for E10, as E10 is a higher fuel to air ratio the LTFT should be +4% not -4% as I thought in the last post. Shell say the V-power is 4% more efficient, so this ties in.
The good news for me is that my LTFT have come back up, bank 1 is now 0.0% and bank 2 is -1.5%. I somewhat agree with Stl-986, ignore the values of FT, just check it now and again, after all if it is running well, why worry?
I have learnt quite a bit about how a modern car sets it's fuel usage, it has been interesting, most of my real experience with this comes from motorbikes from the 70s and 80s, then you just looked at the plugs and fiddled with the air screw or jet on the carb.
Robin
Old 11-19-2021, 07:59 AM   #15
WP0ZZZ98Z1U6XXXXX
W - Germany
P - Porsche
0 - Sports car
ZZZ - Europe/RoW
96...6 - 986
Z - Europe/Row
1 - 2001
Fuel Trim
E10
Robin
I have never seen an automobile that ran constantly with 0% fuel trim.
There is always going to be some correction (fuel trim). To many variables to even make it possible to operate under 0% fuel trim at all times.. Things like engine condition, air mass (density) which changes with altitude, temperature, humidity. Driving style, engine load, fuel, ect,ect,ect.
14.7-1 AFR is only ideal under a very limited engine operating range.
The engine needs a rich mixture at times as well as a lean mixture at other times.
Catalytic converters need a fluctuation in AFR (fuel trim) to operate properly.
Emissions are not cleaned up with out that fluctuation in AFR's
Even in the days of carbureted engines AFR needs changed according to demand.
The only time I would start worry about fuel trim numbers is if fuel trims begin to exceed + or - 10%.
Most manufactures of the early 2000's limit is + or - 25%
The other times I look at fuel trims is to help diagnose other issues.
Old 11-20-2021, 09:20 AM   #16
DrRobin's Avatar
New MAF sensor arrived yesterday and fitted this morning, my car is still running well. To be honest, it isn’t really any different to the cleaned MAF, but when I catch the light on the new MAF sensor, it’s like a very smooth mirror and doing the same on the old sensor you can see the dirt, so don’t think the old sensor will be much use.
It looks like I am finally fixed, just in time for the bad weather and possibly snow, so I guess I will be using my 4x4 rather than my Boxster for a bit.
Robin
Old 11-20-2021, 09:42 AM   #17
Robin
A positive end result even if you have to wait for decent weather to enjoy it.
