-   -   Airbag cover cleaning (http://986forum.com/forums/boxster-general-discussions/81812-airbag-cover-cleaning.html)
timc01 11-09-2021 01:04 PM
2000 986 base - 4 spoke steering wheel
I need to give my steering wheel airbag cover a good clean. I think it's been sprayed with cleaner one too many times and only lightly wiped (to aviod the horn going off) so it appears there's a build up.
Am OK just disconnecting the battery (making sure I have the radio code), and then giving it a good clean or do I need to go through the whole airbag removal, taking the charge out etc.? Just very cautious when it come to 20+ year old airbag!!
RedTele58 11-09-2021 01:49 PM
I'd disconnect the battery and wait 20-30 minutes before I'd mess with it. (That's the usual time recommended before you should try to remove it.) I'd be comfortable giving it a good cleaning at that point.
timc01 11-09-2021 04:25 PM
Thanks, I'll give thar a go. Will also try and free up the fore/aft movement at the same time. Can't move it at present and when I give it a good tug the horn goes off!
dghii 11-09-2021 05:43 PM
A wet magic eraser will cure your ills....no need to remove the bag. Also, Wipe the eraser on your 'clean' steering wheel and see what happens!
2ata 11-10-2021 06:41 AM
I would comment that, while this may work, keep in mind that melamine foam is actually a very fine sandpaper. I'd be cautious of surfaces, leather steering wheel being one.
Quadcammer 11-10-2021 08:52 AM
no need to be shy. you can give it a good hard scrubbing without disconnecting anything
timc01 11-11-2021 02:23 PM
I did use the. Magic Eraser and it worked. But I do agree you need to know when to stop with it, it can clearly do more harm than good.
subieworx 11-13-2021 06:41 AM
Magic erasers can also remove dye from leather so be careful as that black stuff you see coming off surfaces may not be dirt.
