Old 10-22-2021, 09:53 AM   #1
Vza
2018 987 overheating
So I purchased a 2008 boxster w 42000 miles from a scrapyard. Took for its maiden voyage on the highway and the engine overheated. I added some coolant before leaving cause the low coolant light was blinking. About 40mins in the temp gauge jumped and was pinned to the right with no gradual increase. I also smelled electrical burning. Warning light blinked engine too hot. Immediately shut down...cooled off got it home. The 'eng.too hot 'came on again as I pulled in the garage. Hope I didn't do ant damage to the engine. Today it cranked right over....let in run half hr and the temp gauge didn't move. This issue is the 1st to fix on this long restoration. I'm thinking the thermostat isn't opening and probably needs to be replaced along with the temp sensor. Or...faulty temp sensor isn't allowing the thermostat to open....no signal. Any help would be great. V
Vza is offline   Reply With Quote
Old 10-22-2021, 10:14 AM   #2
PLP
PLP's Avatar
Well, not being certain how the cars burp, but I would be willing to bet it was not bled and air pocket cause some trouble.
Then, with the hot condition, it burped and was fine since then.
I do not have extensive experience with them, yet seeing how long the pipes are and where the radiators are - I can imagine the system being very finicky about air in coolant.
Does 987 have same bleeding procedure as 986 (pull the valve and let it run with it open)?
PLP is offline   Reply With Quote
Old 10-22-2021, 01:44 PM   #3
The cooling system should be filled under vacuum to eliminate any air entrapment/
Old 10-22-2021, 02:07 PM   #4
husker boxster's Avatar
This morning I left a response to your duplicate thread in Perf & Tech section.
1989 928 S4 5 spd - black
