Old 08-11-2021, 07:22 AM   #1
Jay
2003 Boxster-S 3.2, AOS lower clamp trouble
Hello,
I am replacing AOS on my 2003 Boxster-s 3.2 and having hard time removing lower clamp. Please note 2003 boxster has different AOS design (please see picture) and there are no bellows.
The issue: I am trying to reach AOS lower clamp from passenger side but can't see the clamp as it is hiding under the AOS so I am trying to go by feel (I have moved oil filler tube out of the way) and I can see the clamp from driver side but can't reach (I am not 10 feet tall).
Any tips on how to reach and remove this clamp? (BTW: It is porsche compression/spring clamp)
2003 Boxster-S.
Black with Tan interior.
jay2015 is offline   Reply With Quote
Old 08-11-2021, 07:59 AM   #2
Originally Posted by jay2015 View Post
Hello,
Old 08-11-2021, 08:23 AM   #3
78F350's Avatar
This is on a 2000 model, but the position and reach is still the same:
Old 08-11-2021, 12:18 PM   #4
Jay
I think it is different as the clamp and bolts both are above engine and access is better from the top. I don't know how the clamp can be reached from wheel for 2003 986-S. upto 2002, the AOS had bellows where the clamp and bolt where better suitable for approach from right rear wheel. Porsche redesigned AOS for 2003+ 986 and same AOS is used for 987.
Thanks,
jay
2003 Boxster-S.
Old 08-11-2021, 11:33 AM   #5
Jay
Thanks JFP, your advice is always valuable.
I guess time to spend some money on one-time use tool. I see that autozone has decent quality for $35, the similar tools on amazon has mixed reviews.
2003 Boxster-S.
Old 08-11-2021, 12:07 PM   #6
I used the above tool twice. Last week for AOS and 9 years ago to replace the coolant tank. It's cheap. Trust me.
mikehkang is offline   Reply With Quote
Old 08-11-2021, 12:17 PM   #7
Wait. You have 2003. The above tool was useful to undo the bottom hose clamp you see in 0:33 of the 78F350's video. If you are trying to remove the bottom 'quick connect', I can't see how above tool will help.
Old 08-11-2021, 12:24 PM   #8
Jay
There is a hose that connects to bottom of AOS (on that thin portion, the portion which looks like a funnel) and it is clamped, that hose turned 90 degree and connects to engine.
I was able to remove quick connect breather tube very easily, I pressed the top of clip with one hand and pulled gently and it was released in less than a minute.
2003 Boxster-S.
Old 08-11-2021, 01:37 PM   #9
Less than a minute?!!
THAT took me a day and only after destroying the breather tube. :ah:
Jeez... I need to upgrade to 2003!
BTW Jay, Can you upload a picture of how your car looks when it is in engine service position? Even though I have 2001, I 'upgraded' to a 2003 top so I don't have to Porsche Chop. Having done so, I have EXTREMELY difficult time accessing the engine bay. How much space do you have from the top? Let's see some pictures when you have time. Thanks
Old 08-18-2021, 02:32 PM   #10
Jay
The clamp on my aos was at weird angle where I could not even fit the cable operated pliers. The clamp on engine side for that small hose was so close to engine that there was no space for even a flat screwdriver. I used pliers to move the angle of the clamp on engine side than use small pliers and I was able to remove AOS with the small hose. I got a new hose, put that on the aos first with clamp in the right angle and slide the assembly on to the engine. The throttle body and intake distributor was cleaned and cars works great.
