Old 07-01-2021, 05:35 PM   #1
986 1999 throttle cable stretched?
Yesterday in traffic when I pressed down the accelerator pedal I noticed it moved a few millimeters freely until it engaged. Now it has some free play, seems like the cable has stretched. Is there a common failure point of the cable? The rear section looked perfectly fine when I put the engine in, so did the converter with the plastic roller that connects the rear and front sections. The pedal seems ok too.
Old 07-01-2021, 06:02 PM   #2
Motorist & Coffee Drinker
78F350's Avatar
I have read that there is an adjustment for slack at the right angle joint, bottom of the firewall. Maybe one of Woody's posts, maybe rennlist. I'll post if I find it.
Edit: Take a look at this: http://forums.pelicanparts.com/boxster-cayman-forum/607597-non-e-gas-throttle-cable-adjustment.html
and this: https://rennlist.com/forums/spec-boxsters/802764-throttle-cable-adjustment.html#post11176707
...Still not the post I was looking for though.
Old 07-01-2021, 08:41 PM   #3
Edit: Take a look at this: Non e-gas throttle cable adjustment?? - Pelican Parts Forums
Thanks, these are useful links . I`ll try to find some time to raise the car and take a look. Hopefully the cable won`t snap before that..
