Old 07-01-2021, 02:44 PM   #1
986 Accelerator pedal pin out
Does anyone happen to know the pin out on the accelerator pedal sensor underneath the dash of a 2001 986. I have tried searching without any luck. I do have the 986 wiring schematic but unfortunately it is in PDF format on my computer and the pages don’t really lineup the best when tracing wires. If this post doesn’t get much info I will have to print it out next week when I go into work so I could piece it together I was just trying to get this done over the holiday break any help is greatly appreciated.
Reef is offline   Reply With Quote
Old 07-01-2021, 04:42 PM   #2
If you have the wiring that is going to be the best to look at, it's what I would look at to tell you.
it's sometimes best to print out the pages then line them up and tape them so you have 1 really big sheet.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 07-01-2021, 07:03 PM   #3
Motorist & Coffee Drinker
78F350's Avatar
I don't have the pedal end handy, but the DME side may help track it down:
40 pin connector 4, IV or D depending on source.
Pin 7: GND Pedal Value Sensor 1
Pin 8: Signal Pedal Value Sensor 1
Pin 9: +5V Pedal Value Sensor 1
Pin 12: GND Pedal Value Sensor 2
Pin 13: Signal Pedal Value Sensor 2
Pin 14: +5V Pedal Value Sensor 2
Old 07-02-2021, 09:27 AM   #4
Thank you very much that helps a lot.
Old 07-02-2021, 11:37 AM   #5
Thanks. Just giving an update I was able to trace the wires and get everything wired correctly.
