Old 06-29-2021, 03:29 AM   #1
99 convertible top
My friends 99 top went down, now won’t go up. Nothing happens when switch is pushed. Seems electrical. Thoughts, ideas?
DWBOX2000 is offline   Reply With Quote
Old 06-29-2021, 04:17 AM   #2
Does the parking brake light come on when you engage it? Mine did the same thing because the parking brake sensor failed. Had to convert to manual operation for a bit until I got the sensor replaced.
-tWv- is offline   Reply With Quote
Old 06-29-2021, 06:54 AM   #3
Top went up today? Weird. Where to start?
Old 06-29-2021, 08:06 AM   #4
That is the same thing mine started doing.
Then I noticed as tWv stated that the parking brake light on the dash was not coming on when the top failed to go up or down.
So I removed the micro switch on the hand brake and cleaned it.
No more issues.
Old 06-29-2021, 08:22 AM   #5
Rob175's Avatar
blue62........ for future reference please explain where the micro switch is located?, how to access it? and a a pic if you have it........helps us all.
thx
Rob175 is online now   Reply With Quote
Old 06-29-2021, 08:47 AM   #6
thx
Just replaced mine, here`s a useful video on how to do it:
https://www.youtube.com/watch?v=VcBqJEtEGHs&t=3s
Before I replaced it, I had been using the top for months by shorting the switch`s connector at the double relay, that also works.
Old 06-29-2021, 01:53 PM   #7
1998 Boxster Silver/Red
In addition to the EB... you might also check the microswitch in the latch. Poke your finger in there a few times... or remove and inspect.
1998 Porsche Boxster
