Old 06-18-2021, 07:30 AM   #1
Looking for strut advice for my 2001 Boxster S
I had a mishap with my car and it's been a month and I thought the car would be finished today. Went to put in the left rear hub carrier after replacing the subframe, axle, and all the control arms, and noticed the bottom of the strut is slightly bent. Closest place I found one from a S is used is in California.
Question, are the struts different from the base verses an S, and are the springs different too and I should only be searching for an S strut.
My strut P/N is 986 333 051 20.
Since I'm trying to get my car on the road today, what aftermarket one would match up to the others that a shop or store should have in stock.
Jasper7821 is offline   Reply With Quote
Old 06-18-2021, 07:38 AM   #2
I don't know about base vs s oem specs, but I have read that the s suspension is 25% stiffer than base setup so I would imagine they are different. In the world of aftermarket coilovers, the same coilovers are used for base and s models and then adjusted to driver preference.
I would caution you about mixing and matching parts. If you replace one side, I would recommend replacing the other. If you don't, usually it will cause premature wear to both sides. Also, I would not rush this process. If you make a bad choice, or get a bad part, you will likely wind up having to do it over again. Just my 2c.
Old 06-18-2021, 07:46 AM   #3
Thank you, that's why I was looking for a used one from an S and hopefully it would be about the same condition as the other 3. The car has 107k miles and looks like the struts are original. The car drove great and struts were still fine.
And yes, totally understand about not rushing. Was just hoping to get back on the road today.
Old 06-18-2021, 08:45 AM   #4
bcrdukes's Avatar
Don't mix and match. It's not safe and please do not buy used. I'd rather buy some weirdo brand from say Rock Auto if you're looking to save some money, but depending on what your plans are for the car, get a nice aftermarket suspension like Koni Special Active, Koni Yellow, or the usual Bilstein replacements.
2001 Porsche Boxster S
bcrdukes is offline   Reply With Quote
Old 06-18-2021, 09:43 AM   #5
Ya, I'm kinda thinking about biting the bullet and just doing all of them.
Old 06-18-2021, 08:55 AM   #6
PLP
PLP's Avatar
No, they are not fine...
You just do not know it yet.
There is no way that struts after 100k miles hold OK. They might not leaking, they may seem to be fine, but the dumping forces are nowhere close to specs.
I am afraid that by replacing the one axle only, it will disturb the balance of the car.
I feel you, man, spending tons of money on a car and not to expect to recoup it is painful.
I am in the same boat.
I just got 2003 Base with 110k miles. I thought clunks are sway bar links. Yes, they were shot, but the clunks are from the suspension.
Overall, after a few hours of searching, looking for deals and so on - I obtained all pieces of the suspension (struts, arms, mounts, links...) for about 1'800 using KONI reds.
Yes, about 1'200 more than I expected, but at least I will be able to feel safe in the car.
PLP is online now   Reply With Quote
Old 06-18-2021, 10:18 AM   #7
Thank You,
I totally understand and may just do all 4.
Old 06-18-2021, 09:51 AM   #8
bcrdukes's Avatar
You'll like the Koni Special Actives. Puts a smile on my face every time I take the car out and makes it so civil to daily drive.
Old 06-18-2021, 10:20 AM   #9
Thank You, we'll see what happens.
Old 06-22-2021, 08:27 PM   #10
Struts that are that old are done… period. If one is dead, replace them all. I just put in Feal coil overs did a full suspension go through, corner balanced and aligned. Completely transformed the car, my wife even noticed. 02’ S with 65k on the clock.
Old 06-23-2021, 11:12 AM   #11
The struts I had worked great and the car drove perfectly fine. The issue was when the wheel folded up it bent the strut, that's why I got a used replacement.
Still looking at replacing all 4 in the next few months.
Old 06-23-2021, 12:18 PM   #12
PLP
PLP's Avatar
Suspension (all 4 corners, all new parts - some OEM, Meyle, TRW, URO, and KONI) less than 2000 USD,.
Old 06-23-2021, 09:46 PM   #13
Thank You, I may take advantage of the 20% off the Koni shocks, we'll see.
I bought control arms from ********************************AZ and they're just under $100 there, plus they had great prices on the other suspension items I bought.
https://www.********************************************** **************/pn/4160500000
Old 06-24-2021, 05:13 AM   #14
PLP
PLP's Avatar
You cannot use certain names here... otherwise you will become an asterisk or a star
for example, automotive store with rock name in it, shall be called stone auto?
not sure about auto and zone
you get the idea, right?
To get free shipping, you need to order each strut separately, otherwise they drop you $50 shipping charge.
Pelican seems to have the lowest price. I saw a set in my local store (via eBay), but they never responded... so forget them.
From what I hear - URO, Meyle, are OK brands for more important parts. Bellows or strut bumps - HT is fine...
Old 06-24-2021, 07:16 AM   #15
Ahhh ok got it, sorry about that.
