Old 06-13-2021, 11:02 AM   #1
Vza
Stuck Key
Hi all, 2008 Box Base. My key is stuck in the ignition. Heard things about a fully charged batt.not too sure if thats correct. Will try paperclip later. Any thoughts? V
Vza is offline   Reply With Quote
Old 06-13-2021, 02:00 PM   #2
987 might be different then the 986, might want to ask over on the 987 forum on rennlist.
define stuck
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 06-13-2021, 07:14 PM   #3
Vza
Got it out with the paper clip but it gets stuck again after starting. Maybe the batt. or ignition switch. I will need a new batt at some point so i will try that 1st. V
Old 06-21-2021, 02:09 AM   #4
Jiggle the key while pulling outward gently. ...
Wrap one or two ice cubes in a plastic bag and hold them against the key. ...
Stabilize the lock mechanism by pushing against it with one finger or hand while you turn the key with the other hand.
Check out our beautiful website if you are interested in cars and <a href="https://cash-cars.sydney/cash-for-old-car-in-sydney/">old car</a>.
akbaradeli is offline   Reply With Quote
Old 06-21-2021, 06:33 PM   #5
Wd40 specialist dry lube - it's liquid ptfe (Teflon, goretex, you get the idea). Safe for electrical components. Works like a charm on lock tumblers.
You may want to disassemble the ignition switch and fully clean it out. You'd be surprised how many metal shavings and dirt you'll get out of there.
Old 06-21-2021, 07:54 PM   #6
Replacing the battery to fix this issue is a waste, it wont do a thing to fix it.
Replace the ignition switch and spray the lock with your choice of lube.
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
