-   -   Having a hard time trying to find used apron plastic covers that go under the car (http://986forum.com/forums/boxster-general-discussions/80782-having-hard-time-trying-find-used-apron-plastic-covers-go-under-car.html)
Jasper7821 06-06-2021 07:09 PM
Looking for some used plastic underneath pieces for my 2001 Boxster S and can’t seem to find any. Mine only have one bolt hole that’s torn but they connect to other pieces so I need to replace them
Just trying to not have to buy new.
Front left fender well apron 996 504 203 06
And the long piece that goes across the car in front of the rear wheels 986 504 119 00
And also the rear left cover in front of the wheel 986 504 571 01
Stl-986 06-07-2021 06:37 AM
Buy new ones, they are cheap. used ones shipping will be more. new you can get free shipping.
Jasper7821 06-07-2021 07:04 AM
Each one is $200, so $400 for having a screw hole broken out is a little more than I wanted to spend and they still mount up fine, just not closing the gap on the other piece it connects to. So for a little cosmetic imperfection, I wish I could find them used.
PLP 06-07-2021 07:07 AM
I am in the same boat... those plastic shields are darn expensive.
Jasper7821 06-07-2021 07:44 AM
Yes they are, if I can't find used now while the car is in the air, I may just put them back on and keep searching for used.
Side note, I like your electric cars. I used to have Focus electric, and now a Fusion Energi. Also had a 500L and it was a fun car. Waited in line years ago for 2hrs for the 35k Model 3 reservation that came out at 50k and never got it. Now waiting for my Cybertruck. Having solar helps a ton.
PLP 06-07-2021 08:21 AM
Being in AZ helps a lot solars. :D
Not justified investment in MI...
As for EVs - Boxster seems slow, at least up to 50 mph, which I got as a toy car.
Stl-986 06-07-2021 10:49 AM
I just did these on mine. Didn't do the wheel wells yet but the front, long center piece & engine cover were cheap. Just saying that finding a used one in perfect condition isn't going to be easy. These all break at one point. If only 1 hole is broken I dont think it's worth it but that is just my opinion. Used ones I have seen cheap but then shipping being almost the same price as new.
996 504 203 06 - $159
986-504-119-00 - $133
986 504 571 01 - $17.40
TeamOxford 06-07-2021 11:37 AM
You could always cover the broken bolt hole with a large black plastic washer and still fasten the piece to another piece with a bolt. I've done this on the rear mud guards of my Cayman. Those pieces snap off easily.
Just sayin'.........
TO
Jasper7821 06-07-2021 11:51 AM
The Porsche dealer in Vegas is selling them pretty cheap, but shipping is $200. My dealer here said he'd price match but also had to add whatever shipping cost they had. I'm thinking Pelican may be the best bet.
If I could find used in Phoenix, I could take a short drive there over the weekend.
And the rear may be ok with the one hole gone but the front fender well has two holes. We'll see.
Stl-986 06-07-2021 12:09 PM
Shop other dealers, you can get all of those with little or no shipping. I got mine from the dealer in Silver Springs and didn't pay any shipping.
Jasper7821 06-07-2021 12:50 PM
That may work for the rear apron, but the front has a bigger crack and covers two holes.
Thanks for the idea :)
TO
Jasper7821 06-07-2021 12:51 PM
Pelican is $50 for shipping, strange that the dealer was $200.
I'll keep trying.
Stl-986 06-07-2021 05:48 PM
Sent you a PM
elgyqc 06-07-2021 07:53 PM
Why not just patch them? I used some fiberglass to cover the broken area. Or glue a piece of plastic to reinforce and drill a new hole. This is not rocket science.
A8ked 06-07-2021 08:12 PM
I had the same problem finding used replacements. One recycler I spoke with told me that most yards use forklifts to move the cars around and these bottom panels get broken in the process.
I ended up buying new ones from Pelican, but included them with some other parts to qualify for free freight.
Jasper7821 06-07-2021 09:04 PM
Originally Posted by Stl-986 (Post 637009)
Sent you a PM
Thank you, I searched them today
Jasper7821 06-07-2021 09:06 PM
Thank you, this may work, the broken sections are not visible u less under the car so it may not matter. Still waiting on a hub carrier, rim, and a few tires, and repair of a rim. So I have some time to figure it out.
78F350 06-07-2021 09:27 PM
I have a Polyvance plastic welding kit and have repaired plenty of these cracked panels and a few bumpers.
Take a look at this: https://www.polyvance.com/video/airless-plastic-welding/how-to-secure-a-broken-fog-light-mounting-boss-2
You can use the basic concepts shown with a cheap soldering iron and scrap of similar plastic.
Gilles 06-07-2021 09:27 PM
+ 1 Learned to use fiberglass by building remote controlled sailplanes (gliders), and used the same 'technique' (low tech btw..) to patch my car plastic parts and they last a long time :-)
dghii 06-07-2021 09:39 PM
Does this help?
http://986forum.com/forums/boxster-cayman-parts-sale-wanted/77664-misc-parts.html
itsnotanova 06-08-2021 05:40 AM
Of the 70-80 boxsters I've bought, only two had a good rear plastic cover. At this age almost everything plastic is getting brittle.
Jasper7821 06-09-2021 02:50 PM
Thank You, none of those would work.
Originally Posted by dghii (Post 637020)
Jasper7821 06-09-2021 02:52 PM
I ended up buying all new pieces.
