-   -   Boxster Convertible- Window not auto closing (http://986forum.com/forums/boxster-general-discussions/80601-boxster-convertible-window-not-auto-closing.html)
Aaron7 05-23-2021 05:27 PM
New to the forums! Recently started to have a problem with my Porsche. I drive a 2006 Boxster Base Convertible. When I open the door my passenger side door automatically goes down bc of the convertible. When I shut the door it does not auto go-up like it used too. It leaves a 1 inch gap. Rather annoying after awhile because I always have to manually use the window up button whenever the door is opened. I'm trying to figure out what switch I need to order to replace the part. These are the only parts I've found but I'm unsure which to buy or if they are the right ones at all. Any help is appreciated, mahalo!
Porsche Window Motor with Control Module
https://www.pelicanparts.com/More_Info/99762418206.htm?pn=997-624-182-06-OEM&SVSVSI=1057&DID=5078
Porsche Door Window Regulator (Electric, without Motor)
https://www.pelicanparts.com/More_Info/98754207603.htm?pn=987-542-076-03-M1253&SVSVSI=1057&DID=17700
